Old 04-20-2006, 08:02 PM   #1
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Upper A arm bolts
Anyone replace the bolts that go through the frame for the upper a arm?
The ones I ordered from LMC seem to be a bit too big and wnt fit through the frame.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 04-21-2006, 01:15 AM   #2
qksilver
Re: Upper A arm bolts
They should have splines, slightly bigger so when you press them in they are tight
qksilver is offline   Reply With Quote
Old 04-21-2006, 08:43 PM   #3
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
They were noticably bigger and the spine was twice as long.
I called a GM dealer kinda near here and they said they can get them in 3 days so I think the project is kinda on hold till then.
I'm just going to send the others back to LMC for a refund.
I'll take a few pics to show the difference.
Old 04-22-2006, 04:52 AM   #4
GMCPaul
pebbleboy in 71 they made the upper a-arm bolts a larger diameter and discontinued the smaller diameter bolts, the bolts your dealer will get you will be the same larger diameter as those from LMC, your supposed to drill out for larger diameter when replacing the old ones, if I remember correctly they went from either 7/16" to a 1/2" or from a 1/2" to 9/16".
GMCPaul
GMCPaul is offline   Reply With Quote
Old 04-22-2006, 06:50 AM   #5
70GMCer
70GMCer's Avatar
That's good to know.....thanks GMCPaul
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-22-2006, 07:46 PM   #6
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Here is a pic ot he bolts.
The shiny one it the one I got from LMC pn 30-0269
the funky one is the org I am trying to replace.
I'm not sure you'll be able to see the size difference but with what GMC Paul said it's correct. I was also wondering why the spline has almost been trippled.
Like I said a Chevy dealer near here has them on order for me. If those are the larger diameter ones I guess I'll have to drill
