Old 04-20-2006, 09:35 PM   #1
tripleblack
short sell Ford stock
how do you install disk brake spindles...??
i was wondering if anyone could help me. I got new upper and lower ball joints installed and am having trouble intalling my disk spindels. I was wondering do you just keep tightening the ball joint bolts until you can fit the cotter pin through the nut and bolt hole? Thanks for the help
tripleblack is offline   Reply With Quote
Old 04-20-2006, 09:38 PM   #2
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: how do you install disk brake spindles...??
If you can get the spring to compress enought to get the nuts on just tighten.
Threre is a torque setting if you wanna get all techinical
http://67-72chevytrucks.com/vboard/s...ghlight=torque
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 04-21-2006, 12:49 AM   #3
krue
Designated A-hole!
krue's Avatar
With my truck secure on jackstands I put a floor jack under the lower control arm and jacked it up with a friend lining the ball joints studs up in the spindle. Be careful if you do it this way 'cuz you are compressing a big a$$ spring.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-21-2006, 08:03 AM   #4
Joe67
67 is sold
Head up and rent a spring compressor for some added protection
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-21-2006, 09:54 AM   #5
bigjimzlll
bigjimzlll's Avatar
if you are installing newer 71-72 spindles in a 67-70 a arm you will need to use 71-72 ball joints....and have fun with the Tie rod ends.....they will take some adapting
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-21-2006, 10:16 AM   #6
troy destroy
troy destroy's Avatar
if a spring compressor is unavailable you can take a chain through the spring and the control arm and run a bolt through it. thats what i did "just in case". that spring flies out something bad is bound to happen.
you will want the truck raised about a foot or two. once the ball joints are in the control arms put the spindle in the bottom ball joint and get the nut started. next step is alot easier with a buddy. you will need to jack up the lower control arm(under the lower ball joint or spring seat) slowly while holding the spindle in line for the top balljoint. jack up untill you can start the nut on the top balljoint. after getting the nut started jack up untill the truck starts to raise of the lift/jack stands. then you should be able to secure both balljoints to the point you can get the cotter pins in. DO NOT leave the cotter pins out.
good luck. with an extra set of hands this shouldnt take long at all.
Troy Destroy / Dallas,Tx
1963 Chevy C-10 SWB stepside
http://img.photobucket.com/albums/v6...ruck/oldie.jpg
troy destroy is offline   Reply With Quote
Old 04-21-2006, 08:58 PM   #7
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I had a problem getting mine spring to compress enough without lifting the truck off tha jack stands. A fat friend might help in a bunch
Old 04-21-2006, 11:16 PM   #8
krue
Designated A-hole!
krue's Avatar
Only I was the fat one of the two of us.
www.daveramsey.com
Old 04-21-2006, 11:32 PM   #9
tripleblack
i had that problem too.
Old 04-22-2006, 05:10 AM   #10
GMCPaul
We've seen the location height wise where they drill the hole for cotter pin on ball joints to vary within the same brand let alone from one brand to another, many times when installing new ball joints in stock spindles or new drop spindles we find that once they are torqued to the proper spec you are still unable to install castle nut far enough to get cotter pin in hole and twice the hole was almost above the castle nut, if castle nut does not tighten quite far enough on to get cotter pin in hole we sand a little off the bottom of the nut, the 2 times I had it where the hole was almost above the castle nut we used a washer under it, doesn't seem to matter if its top of the line moog or mcquay/norris etc... on the ball joints.
GMCPaul
GMCPaul is offline   Reply With Quote
