Old 07-28-2002, 05:27 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Engine is hard to start in the rain...
I have a 350 in my truck, with a edelbrock 1406 carb, and a 14x3 open element air cleaner sitting on the stock air cleaner spacer above the carb. My problem is, that whenever i drive it for a little while in the rain, it has a hard time starting back up. I will have to crank the motor over about 5 times as long as usual, and it dosen't want to idle just after you get it started. I'm guessing this is because it is getting water sucked into the air cleaner. I THINK that it isn't water in the distriubtor because it didn't do this with the stock air cleaner, and the engine proably wouldn't run at all with water in there. So, is this a problem that i just have to live with, or is there any way that i can keep water out of there?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-28-2002, 05:44 PM   #2
Denny
Denny's Avatar
You might want to check if your distributor cap, coil and wires are dirty or dusty, it could be moisure causing crossfire and making it hard to start.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 07-28-2002, 06:03 PM   #3
Pumkin Truck
Thats just prime!
Pumkin Truck's Avatar
Yeah i'd have to agree with Denny, whenever i go through a big puddle and i get water on any of my ignition system components, (i think its my distributer) my engine bogs down and i have to rev it a bit to keep it from stalling.
*69 GMC short bed stepside with a wimpy six that can barely pull itself.
*99 Chevrolet Camaro Z-28
1 Bad 5.7ltr LS1
Pumkin Truck is offline   Reply With Quote
Old 07-28-2002, 06:16 PM   #4
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
hmmmm
deffinately check the distributer......if it's wet....take a blow dryer to it. Maybe check the solenoid coil????I dunno....maybe.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-28-2002, 06:29 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
cap/rotor and maybe wires need chainged. Classic symptoms.
Old 07-28-2002, 08:20 PM   #6
lukecp
lukecp's Avatar
Ok, i was planning on giving it a tune-up anyway. Maybe it happening after i swapped air cleaners is just a concidince (sp?).
Thanks for the help
