250 V-6 Club
![]() Join Date: Feb 2005
what oil and Tempriture sending units
I have a 70 Chevy c/10 that I am converting from dummy lights to gauges. I need some help with what oil and Tempriture sending units would I have to get in order to fit the 250 straight 6cyl. I have only seen them for small and big blocks
![]() Thanks Ralph
1970 Chevy C/10 6 Cyl. 43k original miles all factory ![]() Never ask a stupid question unless you want a stupid answer ![]() |
![]() Join Date: Jul 2004
Re: what oil and Tempriture sending units
The oil pressure is a mechanical gauge, just run an oil line to the engine, steel is best, with a coil or two in it for vibration like factory, the temp sender should be the same as any small block with gauges.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
250 V-6 Club
__________________ thanks for the rply. any idea where I could get the Steel line for the oil guage? I have only seen copper at autozone. also the temp sender would one fit from a 350 8cyl?
Hunt around, someplace will have steel line, but copper is better than plastic, copper can crack from vibration over time. Sender for a 350 should work. Check parts board, someone may have all the parts you need.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 04-21-2006 at 11:43 AM. |
