Junior Member
4 1/2"/6" on 17's?
Ok, I already looked through the wheel and tire fitment sticky and didnt find what I was looking for. I'm considering a 4 1/2"/ 6" - (2 1/2" spindle and 2" spring) drop kit for my 70 C-10 on 17" wheels. My question is, will I have any rubbing/fitment issues with that setup, or will I need to cut my inner fenders out? Thanks guys!
![]() Join Date: Apr 2005
Re: 4 1/2"/6" on 17's?
What size of tires are you going to use?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Junior Member
Probably a 45 series tire. Could I get away with 255's in the front and 275's in the back?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Yes, you can run a 255/50/17 in the front and a 275/50/17 in the rear with that drop no problem. You must have the wheel backspacing proper though. I run 4.5 or 5 inch backspacing on an 8 inch wide wheel.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-22-2006 at 04:17 PM. |
Junior Member
Thanks man, I appreciate the help!!!!
Junior Member
Will i have to use the extreme drop crossmember or can I get away without it? And also, how hard will it be to bolt in a big block? Will the suspension hold up?
If you go with the dropped crossmember (along with the other drop stuff) you may have to remove/modify your inner fenders due to clearance.
R
