Old 04-21-2006, 11:48 AM   #1
crustysarge
Steering Column Squeak
Did a search and found nothing. My column has a very ligh squeak when the wheel is tuned just a small bit. At center position if I turn an inch or so in either direction I can hear it from behind the wheel. Before I yank the wheel anybody know what it might be?
crustysarge is offline   Reply With Quote
Old 04-21-2006, 01:26 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Steering Column Squeak
Might be the upper column bearing
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 04-21-2006, 02:18 PM   #3
avejoe
Custer had a plan too.
avejoe's Avatar
I've had this problem before. I fixed it by lubing the horn contact.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 04-21-2006, 02:39 PM   #4
crustysarge
What did you use for lube? Silicone spray?
Old 04-21-2006, 04:49 PM   #5
avejoe
avejoe's Avatar
Bike grease, I think. Nothing fancy.
With WD-40 you might be able to get it w/o removing the steering wheel.
Fossil Fuel Glutton
