Old 04-21-2006, 01:05 PM   #1
cobinder
Everything is work in progress
cobinder's Avatar
Hub hope
Hi all, I'm hopeing to tap into your wealth of knowledge reguarding late 70's early 80's front and rear hubs.
I've have slid a 80 GMC 3/4 ton 4x4 chassis under a 1 ton 49 international body. Dana 44 up front and GM 14 bolt out back. I'm wanting to narrow the rear axle 4 inches. I have read that GM did make rear hubs that moved the WMS (wheel mounting surface) in 2" on each side. No other mods are needed just swap the hubs. These are called "type B" they came on chassis trucks.
Anyone ever heard of this swap?
My other question is did GM or Chevy ever have the really huge 4-1/2" hubs. I have seen these on the 76 3/4 ton F@@@S.
I'm wanting to put these on my dana 44 axle and use all GM parts (ie brakes)
It's only for the look I'm after, this truck is going to be for showing more then wheeling.
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
cobinder is offline   Reply With Quote
Old 04-21-2006, 05:16 PM   #2
1969 GMC
1969 GMC's Avatar
Re: Hub hope
Sounds like a cool truck.
The type B are on the right, and they came from the factory on Cab and Chassis trucks and dually pickups with the 14 bolt rear axle.
The type A are on the left, that came on SRW trucks.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-21-2006, 08:46 PM   #3
stan79chevy
stan79chevy's Avatar
Re: Hub hope
for your 14 bolt questions go here http://www.pirate4x4.com/tech/billav...ble/index.html
download the pdf file youll need the acrobat reader thing to read it. that has everything you need to know and then some in it. has all the measurements and everything..part numbers..pictures..its got everything.
for the dana 44? you just want to convert your small lock out hubs to the big lock out syle? chevy made them like that they are the older kind. youll just need to swap out hubs and bearings..your spindles will be ok i think. ive seen the swap done the other way around and i think all that was needed were the hubs and new bearings.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 04-22-2006, 01:52 PM   #4
cobinder
cobinder's Avatar
Re: Hub hope
Anyone have any idea which year and models ran the big lock out hubs?
Old 04-22-2006, 03:42 PM   #5
stan79chevy
Re: Hub hope
you need a pre 76??77?? 3/4 ton with disc brakes. i dont know what year they switched to discs..72-73??
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
