292 questions
anyone know what a 292 would get for milage in a 70 k10 with a 4 speed 3:73s and 33s? how does a 292 compare to a 350? would a header with or without 4 barrel intake give better gasmilage? or would the 1 barrel with stock manifold be be better?
70 blazer/pickup 104" wheelbace |
Cantankerous Geezer
Re: 292 questions
Milage will be about the same as a 350 when properly set up. I would go with a 350 and a good quadrajet carb, they are about the best for milage. The 292 is a good engine, but is compromised on airflow through the head. And parts aren't cheap, due to limited production. But they are a cool engine to have in a truck.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Aluminum slot wheels rule...
Re: 292 questions
It probably won't get-up and boogie like a 350, unless you spent a lot of money. A four barrel, intake, cam and headers would wake it up a bit. It'd act more like a tractor engine then a car engine. Kinda like V6 GMC's.
Re: 292 questions
i've always heard the oldtimers swear they got the best fuel mileage from the 250 six. the 292 got crap for mpg, but it's more of a workhorse. unfortunately, however, no matter what these trucks don't get "good" gas mileage.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 292 questions
A 250 will definitely get better mileage than a 292. 292's are well known as gas hogs.
With your gearing and tires, I wouldn't be suprised if you got 8 mpg or so. I've played with mine a lot, converting to HEI, and installing 3.08 gearing, and I can get 14 mpg most days. This is a 2wd truck with 28 inch tall tires though.
Re: 292 questions
I have a 67 K10 short bed with a 292,4 barrel ,headers and HEI. It has 33" tires and 373 rears and it gets about 12 MPG .About the same as when it was stock when it had the 1bbl and manifold. Chris
#7 | |
Re: 292 questions
I got a 250 I am going to drop into my k-20 and I am going to try a Clifford Intake, Cast Iron Header's from Tom L. and I am still debating whether to put a different Cam in it................IMO, I'd rather have the Inliner, they are different, sound different, and running through a straight pipe sound alot meaner than any V-8............
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
