700 R 4 In a 69 C10
Any one know whats involved in getting a 700R4 to function propely. Cuz the Po on my 69 Just slapped it on and didn't do any thing to make it function properly.
I recently replaced the t.v cable (Trottle valve Cable) so now it shifts properly but there is no over drive in it and I was told that It's controlled through an electrical solinoid. Any info on how to wire it will help. Thank You In advance |
its all about the +6 inches
Re: 700 R 4 In a 69 C10
no... it is controlled by the TV cable. How did you adjust the cable?
Back in the sticks
Like Longhorn said...cable. The wiring is for the T/C lockup. That may be what you are missing.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
lowburb is doing this conversion as we speak. He is using a "painless" harness for the lock-up function. He said it looked to be a very nice kit.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
1997 GMC Sierra Ext 1965 Mustang |
Here's a link explaining the TV system; http://www.tvmadeez.com/article/index.php
Also check out; http://www.bowtieoverdrives.com/index.shtml You need to make sure that you have the electrical system connected so your torque converter locks up when in 4th. If it doesn't you can burn up your trans in a hurry. It doesn't hurt to install a temp gage into your drain plug.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
Opened the throttle, with the cable discconected then pull cable to engadge then press button on tv cable. Do you have any part number for the painless harness?
Thank the rest of you for the links. |
if you have an intake and/or a carb that did not come from the same vehicle as that tranny.. then that may not work (probebly won't work) and is probably the root of your shifting problem.
I hope you are able to park it untill this is resolved becouse it won't talke long to destroy the tranny. Last edited by Longhorn Man; 04-24-2006 at 04:44 AM. |
Its's currently parked but my other question is should I get a tv cable for a 700r4 in a chevy 350 Or which cable should I get. I know that this tranny came from a chevy astro van with a 4.3.
![]() Join Date: Nov 2004
I wouldn't mess with the guesswork of trying to get the right TV cable off a used vehicle. Almost everything GM made had a 700R4 in it from about '83 to '92 or '93. Everything from caprices to camaros to trucks to vans and they were all set up different and most had different brackets, some were carbed, some FI, some throttle body...etc... Your best bet would be to save up about $80 and buy the TV made EZ cable from bowtie overdrives. It takes all of the guesswork out of installing the cable. All you need to tell them is what carburator you have.
Bowtieoverdrives.com I can tell you from experience (trans blew after 5K) that proper TV cable adjustment is VERY important. Hope this helps you .
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
