Pertronix Ignitor installation on '72?
I just recieved my Ignitor and I'm going to put it in today. If anyone's interested I'll take pictures and FAQ the process.
The instructions state that I should connect the power upstream of the external ballast resistor if one is installed - do we have this in the '72? I have an ignition-hot line available in the engine compartment. Looks like the only thing that can change this from a minor install to a major one is the distributor end-play. The air gap between the magnets and the reluctor that mounts to the bottom of the mechanical advance (nice design ![]() I may do my MSD 6AL today as well - we'll see how it goes ![]() |
Re: Pertronix Ignitor installation on '72?
the original distributor feedwire is a resistor circuit so you'll have to run a new ignition wire from the fuse box// check the FAQ section for HEI installation it will show how to tap and run the wire
Thanks!
I've already got the ignition-hot line run, so I'm good. I'm putting in a Painless 3-circuit relay on the fenderwell sometime in the next few weeks, so I had already run the line. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Bill did you end up taking any pics???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Questionable
just a heads-up. this swap for a V8 was covered fully in the latest edition i got of Custom Classic Trucks. i think the cover has a red '56 mail-order Ferd or something like that. it may or may not be the same issue that's in the store (the store gets it for a week or two before paid subscribers get the mag
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
