User #12137
![]() Join Date: Apr 2004
67 fuse box question
this is on a 67 with that came with a 6 banger if it matters
from standing under the hood the lower right red wire in the fuse box lost contact with what ever it is hooked to inside the fuse box and therefor theres is no power to the inside of the cab and had to hot wire it to get it home and i need to know if there is way to temp fix that ? what does it hook to inside the fuse box ? and where does the other end of the wire come out inside the truck or does it ? and is there a way to bypass the part inside the box ( i have never had the box out and have no clue what all is in there ) i got a differant cab to put on the truck and a new harness and really want to drive my truck while the other cab is getting ready to be tore apart and get sum work done to it and i see no reasion to put a differant harness in the old cab just to drive it for a short while and then take it back out and put it in the redone cab, maybe i am just lazy ![]() |
Cantankerous Geezer
Re: 67 fuse box question
Red wire is the main power. It goes to the fusible link by the battery, ignition switch and voltage regulator. You can access the fuse block by removing the bolt on the engine side of the firewall that is in the center of the wire harness connector. Then pull the connector and remove two bolts that hold the fuse block to the firewall. The wires that connect into the back of the fuse box have spade connectors.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
