04-23-2006, 08:16 PM | #1 |
what brake booster will work on my 69
I need to put a brake booster on my c-10 what years will work. I tried an 89 and it will not work.
I need to know also if I need to change the brake pedal and the pin thanks for your help |
04-23-2006, 08:46 PM | #2 |
Re: what brake booster will work on my 69
Unless you have a valve cover interference problem like on a BBC, I would use a 69 ---(67-72). You just need the fulcrum with bracket and then a 67-72 1/2 ton booster. This is the least hassle.
04-23-2006, 08:59 PM | #3 |
I got a '70 out of a Burb off Craigs List for $20. They aren't too tough to locate.
04-23-2006, 10:56 PM | #4 |
'68 C-20 396 CST CC
jamon8,
If you still have drum brakes front/rear you can use a 67-70 3/4 ton double-diaphram booster with the shorter brackets. Those brackets are shorter, like 3.5" while the bigger ones on the delco-morraine boosters are about 5". 71-72 3/4 boosters are different though, they have a rod with a different throw because they are coupled to a disc/drum master cylinder. The 67-70 3/4 ton Bendix boosters are deeper but not as big around as the 71-72 ones and are easier to spot. Just remember to get the brackets too.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES 01 Jetta Turbo Daily Driver 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico |
04-23-2006, 11:28 PM | #5 |
I forgot to mention that I am putting disc brakes off a mid seventies truck but it was a deisel and was hyda-boost
04-24-2006, 12:49 AM | #6 |
'68 C-20 396 CST CC
Then you will need a disc/drum m/c on a delco-morraine booster- and some long 5" brackets.
Autozone has the Booster and M/C for the 71/72 3/4 ton for $109.00 plus a $35.00 core charge. Board members will have the brackets if you ask. New stuff is good. New disc brakes are good.
