04-23-2006, 10:15 PM | #1 |
Just A Tool Hand
will 455 mount up
I have a 455 how can I go about mounting it up? Will it bolt up like a 454?
:hit: |
04-23-2006, 10:19 PM | #2 |
its all about the +6 inches
Re: will 455 mount up
What kind of 455? Buick, Old, or Pontiac?
Anything will fin in these trucks, but it won't simply bolt in. If you are lucky, you'll have minimal fabbing to do, but just about any gas motor you could find will fit. (I have a Cad 500 in mine) |
04-23-2006, 10:23 PM | #3 |
Just A Tool Hand
it is a buick. it is tuned to about 500hp and 567ftlb torq. and it still has the mounts on it but how do I go about finding the right angles and were to mount it in the right spot
:hit: |
04-23-2006, 10:38 PM | #4 |
Aren't 455s bellhousing pattern bop also?So wouldnt an adapter plate be in need or a bop bellhousing?
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
04-23-2006, 10:55 PM | #5 |
Like I said, not a direct bolt in. yes, either a BOP tranny, or an adapter plate would be needed.
As for how to mount it, I say pull the front clip off, remove what is there already, dangle the motor in there bolted to the tranny, See if it's going to clear everything, and then figure how to bolt it down. 73 - 87 engine mount towers are great for odd ball engines. Mine had a pontiac 350 in it, and now the aformentioned cad motor on those towers. Then, simply reroute fuel lines if need be, move battery to other side with an Aux battery tray if need be, hook it all up and head to the muffler shop for some pipe work. Here's how i did my caddy swap, much info which you could use on your swap. (we want pics when you're done) http://www.geocities.com/caddyoneton/ |
04-23-2006, 11:33 PM | #6 |
Just A Tool Hand
well i also got the tranny it is on the motor it is a turbo 400 with no adapter plate
:hit: |
04-23-2006, 11:38 PM | #7 |
AttentionDeficitDisorder
ive got a 455 olds motor in my 72 burb almost a bolt in ordeal.
04-23-2006, 11:52 PM | #8 |
Just A Tool Hand
pics and help please. i'm lost
:hit: |
04-24-2006, 09:04 AM | #9 |
Like a Rock!
455's rock
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
04-24-2006, 09:41 AM | #10 |
I will be putting a 455 Buick in my 72'. But, I am still working on the frame and suspension. The motor and tranny came out of a 70' Chevy truck, I got the motor mounts with the motor, I don't know what they came out of, but they are hacked up abit. It looked like the engine and tranny were in the stock locations.
04-24-2006, 10:07 AM | #11 |
well with the th400 you'll need to convert to a highhump floor
04-24-2006, 02:38 PM | #12 | |
It all depends on how high the engine is sitting once it's all done and overwith, and also fore and aft will help determine that too. |
04-24-2006, 10:33 PM | #13 |
Just A Tool Hand
how much clearance is needed around the bellhousing
:hit: |
