04-24-2006, 11:17 AM | #1 |
Questionable
What did you get done this weekend?
Finally I get to start one of these threads...Pictures speak for themselves, but here are some words:
Girlfriend was out of town, worked on truck 12 hours straight on Sunday. got oil pressure and water temp gauges wired and plumbed. filled the tranny w/fluid. filled engine w/oil. re-mounted the C/K truck dipstick. sanded down the firewall where the brake booster is and painted it. re-mounted the master cylinder for brakes. rewired the trailer lights. modified the driver's side bumper support bracket to fit with the power steering setup. got the throttle cable setup (But not chopped and hooked up to the pedal). got the manifolds torqued down to spec (intake + exhaust). got the harness installed, all wired up, very easy but took a long time. NOTE: noticed skip shift solenoid sensor was deleted, hope this won't cause a problem? i wanted to disable it, but ... i'm a noob i'm really happy with the quality of work on the harness Wait4me did thus far, although some of the wiring (like power ACC and power ON) and the starter stuff seems a tad cheez but 100 times better than i would do!! got the battery box sanded and painted. got the front clip back on and somewhat adjusted, but not bolted down yet. dorked around with the low pressure PS line. gotta figure out how to bend it to make it fit under the inner fender. updated my gallery to include pictures of the driveshaft install and today's work - including my gauges setup on the pan and head. this is a weird sight for me...it's been almost 7 months since i saw it like this last.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-24-2006, 11:51 AM | #2 |
Questionable
Re: What did you get done this weekend?
busy yes - but heavenly. it was so nice to spend quality time with the truck and the thought of actually starting it and driving around is like. .... WOW!
04-24-2006, 11:56 AM | #3 |
I cleaned/stripped my inner fenders and 67 grill. I also gave the Z71 a bath, she was feeling neglected
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-24-2006, 01:09 PM | #4 |
Saturday I did get to work on the truck. my little bit is in this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=196998 Sunday was the evil yard work.
04-24-2006, 01:20 PM | #5 |
Questionable
I saw that, Bill. I was a little jealous. I'm not really ecstatic about the way all of my brackets and other crap looks. I really want to take time to polish it up. I swear, whatever GM does to pour aluminum parts, it leaves so much crap everywhere, lots of slag-looking stuff.
what dremel bit did you use to get the casting flashes off?
04-24-2006, 01:56 PM | #6 |
I did lots and lots of raking and then more of sanding drywall. I officially hate the new house now.
04-24-2006, 02:11 PM | #7 |
Never Done?
I drilled two holes in the crossmember for the bulkheads for the air line. And that's it truck-related. Lots of yard work and did some cleaning on my beater's interior (nasty), and detailed my S-10. Hopefully the next few weeks will lend themselves towards more truck work than anything, now that I've gotten a few spring cleaning chores out of the way.
04-24-2006, 02:30 PM | #8 |
Designated A-hole!
I got my engine back in my truck (replaced harmonic balancer, timing set and a bunch of gaskets, and driver's side exhaust manifold). Got the electric fans mounted to my radiator. Got the cab and core support mounts swapped out. Finished modifying my wiring harness for headlight relays, electric fans, and internally regulated alternator. Finished modifying and mounting my serpentine brackets (not as clean as Bill's). Now (since my weekend lasts until Friday) I gotta get the wiring harness installed and install the Chevy front clip.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-24-2006, 02:40 PM | #9 |
I started to strip the new-to-me bed side to replace my pushed in passenger side.
I have a question about rust repair on the bed: Is there a weld in patch for the floor bolt hole strip? The bed side I got is nice, but the strip is too rusty and the bolts spin. The floor was cut to remove the bed side, so I wanted to blast it, then weld a new angle strip with the square holes and add new bolts. |
04-24-2006, 02:42 PM | #10 |
No truck work here! I did get the grass cut though (followed by the consumption of numerous cold ones!)
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
04-24-2006, 02:46 PM | #11 |
'68 C-20 396 CST CC
I put my hood back on from the whole front crossmember/new M/C and Booster swap I did last weekend, then bled the brakes (again) and changed the lower radiator hose that was dripping on me while I swapped the crossmember...
THEN, I took it for a test drive and the brakes are great...but the radiator decided that the stress from taking the old lower hose off was just too much to bear. Now I have a couple good radiator leaks above the lower hose tube. Two straight pinhole leaks about a half-inch above the tube but not from the tube itself...original radiator with some filler-neck issues anyway but I was hoping to get through the next month. So, I bought a new one online yesterday at radiatorbarn.com for 179 shipped (because I searched the board and found a good link), then I went and pulled a few parts off my parts trucks to sell to lessen the blow of the last three weeks' worth of parts buying. More stuff to sell soon after cleaning them up and painting this week. I haven't even come close to starting the intake/carb swap that I had planned to have done by now... It seems everything takes 3 times longer than I want it to and costs roughly twice as much as I think!
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES 01 Jetta Turbo Daily Driver 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico |
04-24-2006, 02:49 PM | #12 |
I drove mine fishing about 500 miles over the weekend, I washed the windshield...
It is great to have them to where you can drive them... I got 18 plus mpg during the trip running 75 mph. It was fun, but I think I need single piece windows to cut down on the high speed noise. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-24-2006, 02:56 PM | #13 |
SKINNY TIRES RULE!
replaced the waterpump that has been leaking for several weeks. No other truck related work. Sat infront of the computer doing some freelance work the rest of the weekend - and it was 75 degrees outside
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-24-2006, 02:56 PM | #14 |
False Lies
i started to build my front roll pan, and shaved my door handles, fixed up my hinges to open with the key instead of door handles. if i didnt have to work all the damn time i woulda got more done lol.. goal is to get it on the road by my grad (end of june)
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... |
04-24-2006, 04:48 PM | #15 |
Started to work on my 67 that's been sitting for a year. Installed new wiring harnesses, power steering box and pump. aftermarket gauges and automatic shift linkage. Now I just need a shift lever and a couple power steering hoses and I can drive it again.
04-24-2006, 07:18 PM | #16 |
Finished up Tunnel in bed and got all the wood cut up, routered, stained & 90% installed, still have to figure a little detail out on how to access my battery that I also made a battery tray/bracket for and installed it right behind the differential (using a Braille Automotive Battery weighs 15lbs and isnt much bigger than dresser style motorcycle battery). I also made a bracket/mount for the electric fuel pump that will attatch the new fuel tank that will be located in the rear (ordered today, promised next week). Installed rear Roll pan from ClassicPerformance. Hopefully this week get started back on the front and get the front brake lines ran & hooked up, finishup any wiring, some minor mods to engine before putting the nose back on.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 04-24-2006 at 07:20 PM. |
04-24-2006, 07:19 PM | #17 |
More Picks
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
04-24-2006, 07:25 PM | #18 |
Nothings as cool as my 72
Finally finished painting my frame(I had to wait over winter to continue). My dad was cutting my floor out and we found more rust and bondo. Someone who previously own the truck(I dont even know how many previous owners this truck has had)had made the drivers side cab corner out of bondo. Finally got the right oil pan gasket. When I came home from school on thursday, there was a set of flow-tech headers and flowmaster 40's sitting on my bed. So my rolling chassis should be together soon.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
04-24-2006, 08:34 PM | #19 |
A little bodywork on Sat. Sun. I painted the mail box candy blue
04-24-2006, 09:31 PM | #20 |
Mowed,moved 69 k10 frame outside to move 71 in to work on,and took the hood,fenders,door,bumper,grill,and interior out of 71.
04-24-2006, 10:08 PM | #21 |
Designated A-hole!
Update (I only get 2 weekends off a month so one of them is 8 days ) I got the truck started and timed (gotta love being able to use a timing light! ). Now to finish making it a chevrolet and bleeding the brakes (new m/c) and I'll be driving it again.
04-24-2006, 10:16 PM | #22 |
PROJECT 7DEUCE
New frame horns on the blazer along with some new flowmasters to help it get better milage..LOL..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-24-2006, 11:09 PM | #23 |
Chevy Forever
well I have no pics and it was more then just this weekend but in the last week I have installed my engine(402) mounted tranny (TH400+Gearvendors) mounted tranny x member to find out header won't clear bottom of x member so customized it to make room for the Ceramic coated headman headers. I have come to the conclusion that I can go with a one piece drive shaft now since the front part of my original would only be about 10 inches. So need to get that made and need to order brake lines and a fuel tank. I have been telling the wife I need to mount the serpentine belt setup on the engine to see how it looks but since it is outside she doesn't want me to do that. Well as soon as I get some more parts I think I will make some more progress.
My first love 1971 C20 Hugger orange Getting face lift and heart transplant .30 402 BB /TH400 and GV Wifes car 1969 Chevelle SS 396 325hp/TH400 Factroy A/C Automatic w/ Floor shift console. restored. |
04-24-2006, 11:33 PM | #24 |
Roadtrip!
Drove about 2100 miles to pick up the 67 k-30 napco with sakohntr. Not much time for anything else...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-25-2006, 01:59 AM | #25 |
no pics to show but made a ton of progress on my 70 longbed. went from parked beater to nearly streetable in a matter of hours. got my tranny back up to speed. once i got that figured out, i started brakes. bled them out and adjusted them all around. took my truck for its first test drive on sat. it was a great thing. it hadnt moved since i bought it in january. now just got a few things left to do before it gets inspected and sees the road daily. all in all, a great weekend of work.
-justin- 70 chevy longbed: 350/th350 12 bolt project |
