Old 04-24-2006, 11:45 AM   #1
70-Chevy
-Chris
70-Chevy's Avatar
What kind of drop shocks?
I just recieved my drop springs for my truck, 3" front and 5" rear drop coils. Im curious to see what kind of shocks I should get and maybe relocators. What do you all suggest?
Chris
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 04-24-2006, 03:12 PM   #2
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: What kind of drop shocks?
i dropped my 72 3 inches all around and used stock type shocks and havent had any problems.
AesC10s is offline   Reply With Quote
Old 04-24-2006, 08:36 PM   #3
72MARIO
72MARIO's Avatar
Doestec.
They work well.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-24-2006, 09:32 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Originally Posted by 72MARIO
Doestec.
They work well.
Doetsch Tech, with relocator kit from CPP.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 04-24-2006, 10:02 PM   #5
XXL
Seņor Member
XXL's Avatar
Monroe #33033 up front. They're same top and bottom as stock and a little shorter. I had my first set for 6+ years, and liked them very much. Replaced them last year with the same. BTW, this is what ART ships with their kit. Oh, and did I mention that they're ! $28 each
XXL is offline   Reply With Quote
Old 04-24-2006, 10:29 PM   #6
70-Chevy
-Chris
70-Chevy's Avatar
hey xxl, so what size do I get for the rear. You have alotta confidence in these things huh? How much of a drop do you have on your truck?
Old 04-24-2006, 10:30 PM   #7
70-Chevy
-Chris
70-Chevy's Avatar
Also, do you guys think Ill need a adjustable track arm?
Thanks guys,
Chris
Old 04-24-2006, 10:37 PM   #8
XXL
Seņor Member
XXL's Avatar
I remembered the fronts off the top of my head (easy number and all). I'll have to do a search for the rear part number. My truck is fairly low, BTW...
Old 04-24-2006, 10:53 PM   #9
carrzy4
Active Member
carrzy4's Avatar
my drop is 2/4 do i need the relocators or can i just purchase the rear shocks, and what size would that be?
S.h.i.t happens when you party naked.
carrzy4 is offline   Reply With Quote
Old 04-25-2006, 12:20 AM   #10
XXL
Seņor Member
XXL's Avatar
#32077 for the rears.
Also, the only value I see in the adjustable Panhard bar is that you get to adjust it... once. After you've got the rearend centered, there's no value in it being adjustable. Also, with a static drop, you're really not going to benefit from the longer Panhard bars because you won't have a whole lot of suspension travel as compared to a bagged rear. In the case of the bagged rear, the peak-to-peak excursion is in the 8-10" range, so the longer bar reduces the arc the bar travels, and so reduces the side motion of the rearend as the suspension travels up and down. For a static rear, you're looking at 2-4" of real-world spring travel.
Old 04-25-2006, 10:47 AM   #11
70-Chevy
-Chris
70-Chevy's Avatar
xxl,
so all in all, I can keep my stock track bar? Is that what your saying? Thanks alot XXL, youve been alot of help.
Chris
Old 04-25-2006, 12:00 PM   #12
XXL
Seņor Member
XXL's Avatar
Chris
In my opinion, yes. when you lower the truck 5" in the rear, the rearend WILL shiift slightly to left of center (less than an inch), and that's where it will stay (unlike bagged systems, which get moved up and down). If you want to get the rearend re-centered, you can lengthen the stock Panhard bar, or move the left side frame mount to the right a little (it's riveted, so you can pop the rivets out, move to the right edge of the left frame channel, drill, and bolt.).
Old 04-25-2006, 12:08 PM   #13
70-Chevy
-Chris
70-Chevy's Avatar
Thanks XXL, youve been an awesome help.
Chris
Old 04-25-2006, 11:39 PM   #14
Primered_69
Primered_69's Avatar
Do you think those shocks will fit on a 69 with leafs?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 04-26-2006, 12:18 AM   #15
XXL
Seņor Member
XXL's Avatar
For those of you with extreme drops, I just did a reverse lookup of a comparable top/bottom mount for the rear that has shorter dimensions than the stocker
Stock = 32301
top mount LS37, bottom mount LS37, compressed 11.875, extended 18.250, travel 6.375
Shorter unit = 33076
top mount LS37, bottom mount LS37, compressed 10.000, extended 14.625, travel 4.625
Still shorter unit = 34839
top mount LS37, bottom mount LS37, compressed 9.750, extended 14.750, travel 5.000
Even shorter unit (requires small mod to bottom mount) = 37187
top mount LS37, bottom mount L1/CP5, compressed 9.375, extended 14.250, travel 4.875
Old 04-29-2006, 09:05 PM   #16
Tom
driving is in my blood
Tom's Avatar
I've had stock, toxic and doetsch tech's on my 78 with a 5" front drop. The worst were the toxics, they sucked bad. Stock was ok, doetsch techs are a dream. Also use doetsch techs on my 98 with 5" up front, rides great.
Old 04-29-2006, 11:16 PM   #17
XXL
Seņor Member
XXL's Avatar
I swapped out Toxics for DT's on my '99 Tahoe (6/8 drop) and they worked great.
