04-24-2006, 03:05 PM | #1 |
Banjo Bolt and Fitting Question
I bought a front IFS kit from Fatman Fabrications that came with disc brakes. The braided hoses they sent me have a banjo fitting on one end that a 7/16 banjo bolt from my stock brakes will fit in. The new callipers take a 10mm banjo bolt. I called them and told them this and they said that thats the only hose they carry and it works fine. When I hooked up the lines I'm getting a leak at the banjo to calliper fitting. There seems to be a lot of play between the 10mm bolt and fitting. Is this whats causing my leak? I have copper washers on top and bottom and it leaks no matter how tight I go with it.
Thanks for any help. |
04-24-2006, 10:32 PM | #2 |
Hollister Road Co.
Re: Banjo Bolt and Fitting Question
you should have no slop between the bolt and hose end. a 10mm should fit not tight but drop in with little play. if you have the right hoses and bolts then you have the wrong caliper. A 10 mm is not even close enough to fudge it with copper washers. It is most definately why your leaking and don't drive it till you get the proper fitting bolt/caliper/hose combination figured out. you will also need new coppers.
04-27-2006, 12:39 PM | #3 |
Thanks. I will buy different hoses.
