Extreme drop center crossmember troubles!!
After installing the crossmember my truck is now 3" higher in the rear. Due to moving the trailing arm mounting points up on the crossmember to correct pinion angle, my trailing arms now hit way sooner. I already have 2" blocks so i know im gonna have to hack on my truck some more. Would it be safer to hack on the frame, the trailing arms or both? Would i benifit from the tubular trailing arms out there? Im even considering scrapping the whole idea and doing a 4 link. Does anyone have any other ideas before i burn this thing?
Brandon project 67 swb bagged on 20" Coddingtons |
#2 | |
Señor Member
Re: Extreme drop center crossmember troubles!!
A guy with a truck
-Unbolt and flip-over the trailing arm mounts, putting them back in the stock position. Cut off and reuse or get the weld-on perches to correct pinion angle.
-The tubulars may give you some clearance, but not three inches. You would still have to notch the frame to clear them. Maybe combine these two- i.e. flip the brackets/weld on perches, and notch frame/tubular arms. Might not have to notch for the arms in this case. Sucks but that's about it without going four-link. Let us know how it goes. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-25-2006 at 01:16 AM. |
A couple different things you could do.
1. You can cut the perchs off of your rearend and move them in about an 1inch. There is enough movement in the front bushings to do this. 2. Use the factory mounts on the crossmember, and move the crossmember to center wheel in wheelwell. When you lay these trucks out the wheel gets tucked into the front of the wheel well. 3. Go with tubular arms. The ones from CCP will gain some clearance. 4. Go with a 3 inch block. I usually run a 3" block if I am laying it out. 5. Or go with a 4 link and solve all problems. I wish I did a 4 link @ times. Would have saved me alot of time and a smaller notch. My next truck is going with a 4 link!!!! |
#5 | |
Señor Member
WTB this ad
I don't have any interference problems with mine, but it was a mutha to get it in.
#7 | |
Señor Member
for some reason my trailing arm mounts are welded to the crossmember. When i ordered the crossmember they were bolted in the picture, but mine were welded when i got it here. I tried to contact CPP but i havent received a responce yet. Here is a few shots of my issue.
Brandon project 67 swb bagged on 20" Coddingtons Last edited by project76; 04-25-2006 at 07:29 PM. |
Outlandish Trends - FL
hmm, in that last pic it looks like if you route the exhaust through the crossmember you might still have some issues clearing that also.
-Bret 67 short-fleet sold! |
Yeah thats another issue im gonna have to deal with. I finally had a chance to talk with CPP but now i have to call and talk with someone else in the morning. Hopefully i am able to exchange mine for the style that i paid for.
#11 | |
Señor Member
#12 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-26-2006 at 12:06 AM. |
#13 |
After talking with Tech support at CPP i guess im SOL. They do not make the bolt on perch cross members anymore. That was a first run only. I have no idea why they have it pictured this way on the web site. If i had known this, i would have went elsewhere. So i can either send it back and pay for shipping and a restocking fee or try some mods brought up by you guys. Im alittle mad so im gonna take a break for a few days and calm down. Maybe ill end up with a 4 link after all
#14 | |
Señor Member
#15 | |
#16 |
A guy with a truck
I think ECE's is still bolt together. I'd be sure and ask first though...
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#17 | |
WTB this ad
#18 |
That's because CPP used a pic of Early Classic's Crossmember. I purchased mine from ECE. It works great. ECE developed the part and obviously did the research!
#19 |
Have A Nice Day!
I helped my buddy put one we picked up from Early Classic in his 69(his truck is pretty low) and we had no problems. Nice fit and they were great guys to deal with.
![]() 70 CST 4X4
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() Last edited by 70 CST 4X4; 04-28-2006 at 01:51 AM. |
#20 |
Questionable
Got some related no-brainer questions here:
When dropping greater than 5/7 using the stock trailing arms, regardless of whether you're using either ECE or CPP crossmember, your pinion angle is going to be shot, and you're going to need to cut off and re-weld the perches, right? I was under the impression that the lifted angle of the trailing arm mounts for the "extreme drop" crossmembers actually corrected the pinion angle to some degree. Also, a question for see ten - you know, I see under your extreme drop crossmember you have a support bracket under the framerail beneath the bottom two bolts. Did that come with your crossmember? I saw on the CPP unit install in CCT mag that they installed one on theirs in the same location. I'm just curious about whether it's required, and what the purpose is.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 09:10 AM. |
#21 | ||
A guy with a truck
#22 | |
My 68 was @ least a 7" drop in the back w/bags + blocks. I used the stock OE trailing arms & crossmember. This set-up used 1-set of u-joints that were swapped in when the suspension was done @ the time of purchase (they're still in service). No vibrations or issues otherwise in 5+ years of service.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-29-2008 at 10:05 AM. |
#23 |
Questionable
"shot" - "out of whack" - "in need of correction"
e.g., if i want to do this properly with no smacking the frame, no other issues, i'm going to be measuring for proper pinion angles, removing stock perches from my axle and welding them back on in a different place.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#24 | |
No need to cut the perches off either. They make pinion wedges for adjusting pinion angle on trailing arm suspensions.
#25 |
Questionable
Shoulda remembered that, I had to install 2º pinion shims on m '03 Sierra when I dropped it.
![]() Cool, so I'll leave the perches in place and look at the geometry before getting gung-ho and hacking anything off first.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 11:13 AM. |
