Old 04-25-2006, 09:45 AM   #1
smh292
Installing rear coils spring question
Does it matter which way the rear coil springs face? I know for the front there is a little channel that they spring seats into, but for the rear, does it matter which way the springs face? I took both the stock springs off and I forgot to check which way the straight part at the top and bottom faced. Thanks
www.diverserides.com
WTB 67-68 SWB, 350, Auto, Coil frame, Discs up front - PM me with details
smh292 is offline   Reply With Quote
Old 04-25-2006, 12:00 PM   #2
68haywagon
I'm watching you!
Re: Installing rear coils spring question
Here's a pic of the passenger side. You can what direction the spring faces....not sure if it matters as long as the spring retainers fit right.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 04-25-2006, 03:58 PM   #3
Green Machine
Green Machine's Avatar
I usually leave the mounting cups a little loose and spin them around to where it looks like I get the best fit of the spring tail to the lower arm, then set the other side the same way and see how it looks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-01-2006, 09:23 AM   #4
4x4Poet
The bottom on my '72 C10 burb's coils have the flat/straight part of the spring toward the front. Precisely, in fact. I'm the second owner. Pretty sure the springs were never removed before.
Never thought of the direction of the flat part before until this thread. Thinking about it, I wonder if the flat/straight part has to be forward facing because the trailing arms angle up a little at the spring mount and the flat/straight part will clear or otherwise fit the trailing arm better that way. I need to take a closer look.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
