Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-25-2006, 06:55 PM   #1
SCOTI
SCOTI's Avatar
WTB 73~80 Front Suspension
I'm in need of a complete medium-duty (1.25 thick rotor) front suspension (hub to hub) off of a 73~80 GM 1/2 ton pick-up for a disc brake conversion.
The front crossmember is not a must have; these parts are:
upper/lower a-arms + hardware; brake parts: spindles, calipers, hoses, lines (flex & hard), prop valve & related brake fittings; sway bar; & drag-link.
This stuff is heavy so I would be looking for stuff in/around DFW (preferably within 1hrs drive from Dallas/Garland) that can be picked-up.
Hook a brother up!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-26-2006, 08:49 AM   #2
86 GMG
Re: WTB 73~80 Front Suspension
if an 85 model will work i have one here in tulsa hub to hub with member intaked just a few bolt left to undo and drive off?
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 04-26-2006, 10:46 AM   #3
Jonboy
Slots go on anything!
Scot, I have an 89 Sub that should have all of that stuff. The only problem is that it is in Austin. We could whack the frame to get everything you need, though. I also have a tailgate band for you down there, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-26-2006, 11:45 AM   #4
dennislbrooks
dennislbrooks's Avatar
OK- if you use your existing upper and lower a- arms, I have 88 hd spindles with 5 lug rotors (will aslo accept 6 lug) , ball joints, and matched tie rod ends for a 65-70 steering link. Also have a LD 5 lug 87 spindles with outer tie rods also for 65-70 apllication with ball joints.. I do not have calipers, pads, or flex lines for either. Easily gotten from Oreilley's. I do have some prop valves.
dennislbrooks is offline   Reply With Quote
Old 04-26-2006, 04:47 PM   #5
SCOTI
SCOTI's Avatar
We wanted to use the newer style a-arms w/rubber bushings. Thanks though....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-26-2006, 10:25 PM   #6
Lizzard27
i sent a pm to ya
Lizzard27 is offline   Reply With Quote
Old 04-27-2006, 12:11 AM   #7
SCOTI
SCOTI's Avatar
PM back @ you . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2006, 08:58 AM   #8
Lizzard27
sent another pm
Old 04-27-2006, 06:40 PM   #9
SCOTI
SCOTI's Avatar
Back to you . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-01-2006, 09:31 PM   #10
Lizzard27
scoti my dad brought the stuff and is in ft worth tonight i have been trying to reach you check your pm and give me a call thanks
Old 05-02-2006, 06:15 PM   #11
SCOTI
SCOTI's Avatar
I'll check my PM's & give you a call.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-03-2006, 09:08 PM   #12
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
I've got a setup off of a '75 model but I'm located in the Chattanooga, TN area. Probably a lot farther than you'd travel unless you know of someone coming this way.
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 05-03-2006, 10:10 PM   #13
SCOTI
SCOTI's Avatar
Yeah, that's a little too far. I found something pretty local & hope to complete the deal by next Monday. I appreciate the response though.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
