Old 04-25-2006, 10:00 PM   #1
7deuce
Sold! 2 days after finished
7deuce's Avatar
Quick X-member drop question.
What is the biggest X-member drop you can do with still using the stock steering. 1 1/4" 1 3/8" or 1 1/2".ect.... THANKS
7deuce is offline   Reply With Quote
Old 04-25-2006, 10:10 PM   #2
SCOTI
SCOTI's Avatar
Re: Quick X-member drop question.
Do you consider 'stock' as in un-touched/un-modified?
I did a 1.375" notch & had to trim the c-member for tie-rod clearance but it still wasn't enough & the upper a-arm interfered big-time w/the stock automatic column steering shaft so it would have required several u-joints.
I wound up spacing everything 1/4" so I had the equivalent of a 1.125" notch. The a-arm could possibly work w/some trimming (I won't know for sure until everything is re-asssembled).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-25-2006, 11:08 PM   #3
XXL
Seņor Member
XXL's Avatar
As a general response, 1" ... though you can nudge that a little, what's the value of another 1/8"? That's the thickness of a washer.
XXL is offline   Reply With Quote
