Old 07-29-2002, 02:01 AM   #1
carver
air bags
im curious what kinda setup to run or is going to be hard because its on leaf springs
1977 SHORT STEP
carver is offline   Reply With Quote
Old 07-29-2002, 03:47 AM   #2
jay-dawg
chevelito
jay-dawg's Avatar
sup man,
I'm not the bags guru here but you have 4 choices for the rear. Air over leaf and 2/3/or 4 link. Then after you have decided what to run, there's ready made sets from air ride technologies or easy street. There are also places that build them from scratch. As for what you want depends on how much money and what you are going to do with your truck.
I have the air ride air over leaf system on my s10 that uses mono'd stock leafs and it is pretty good. I got a chance to test it with a load of tables and chairs (I would say about 500-600lbs worth) and it just squatted and took the load. Downside is that I get some rear hop. So if you have a v8 in it or maybe even a v6, you may want to go with the links.
If you have more questions, check out the sportruck.com forums. There are alot of great guys (some are dealers so you'll get alot of info) on the board.
slammed...maybe you want to add to this?
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 08-02-2002, 12:08 AM   #3
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Cool
OK, here's the skinny on BAGS. I had a 72 with leaves, that would almost lay frame on 17's, about 1" off the ground.
Just cause it is leafs doesn't make it harder.
#1 Try to avoid the mono leaf it causes bad wheel hop as Jay dawg said, I took my full stock leaf pack (including the overload spring) to a local spring shop and DE-ARCHED them a full 5".
Flip kit to relocate the rearend on top of the springs, 2" shackles, and a BIG C-NOTCH if you wanna LAY FRAME.
The front is a snap, 2.5 drop spindles, and bags and your done it will LAY OUT NICE!!! Check out my store in my sig, I can hook ya up. Here's a pic of the 68 UNDER CONSTRUCTION
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 08-04-2002, 01:41 PM   #4
72chevyLWB
Got 20's????
72chevyLWB's Avatar
What exactly would a person need to do the bags? I am looking at maybe just baggin' the front for now and later on do the rear. What do I need? I would want a very small compressor and tank. What do you recommend and how much do you think it would run. If you can shoot me a price.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 08-04-2002, 04:43 PM   #5
PushinPebbles
My dad's 68
PushinPebbles's Avatar
Pick up a TRUCKIN mag and look up Aim industries
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 08-08-2002, 03:51 PM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
Air Ride Technologies is the best. Stay away from AIM/Chassis Tech...............Pure crap!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 08-08-2002, 05:45 PM   #7
jay-dawg
chevelito
jay-dawg's Avatar
air ride and easy street both make kits for our year trucks. what you need depends on what you want to do with it. Check out their websites and they should give you a list of what is in their kits. Also, Nsane caters to our year trucks and could probably give you a list of things.
shoots,
jay
Old 08-08-2002, 06:20 PM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
Air Ride Technologies offers a 100% bolt-on kit for the front---Cool-Ride kit. The OEM shock mounts are used as well. For the rear, a weld-in 4-link using F9000 air bags would be best. QA1 billet aluminum adjustable shock absorbers would be next. Top it off with the ARC4600 4-way RIDEPRO MAX system, and you would have an awesome setup! Reliable, durable, quick, and etc.. Not a crappy setup using AIM/Chassis Tech components.
Here is the ARC4600 compressor system!
Old 08-08-2002, 06:41 PM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
4-link with F9000 air bags. Except, our kit is equipped with the second picture mounts.
Old 08-08-2002, 06:42 PM   #10
BaggedC10
Under construction!
BaggedC10's Avatar
Old 08-08-2002, 06:50 PM   #11
BaggedC10
Under construction!
BaggedC10's Avatar
HAL QA1 billet aluminum adjustable shock absorbers.
Old 08-09-2002, 01:04 AM   #12
Slammed67
Progress = 0%
Slammed67's Avatar
LowC10 forgot to mention onw thing..... the PRICE! It's very expensive to just go out and buy the top of the line bolt on kit. I bought my stuff from AIM and pieced together a system for a lot less than what a kit costs. Just remember, kits aren't the only option.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 08-09-2002, 01:08 AM   #13
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Talking
Ok I set back and kept quite for a while.
I have used CHASSIS TECH suspension components for over 6 yrs.
I am now a authorized CHASSIS TECH DEALER, along with many other companies including DJM, FIRESTONE, DOESHTECH, TOXIC SHOCK, ect. ect. I have NEVER had any problems of my own, nor have any of my customers. I have built over 10 custom vehicles over the past 6 yrs, some mine and some my friends, and ALL WITH CHASSIS TECH PARTS.
I will stand behind all the parts I sell 100%. I have been a member of this board for a while now, long before I was a vendor. This board is like my extended family, and I would not sell so called CRAP to a friend or family member.
I am currently putting together a kit to offer to board members, that will be about $400 dollars cheaper than the afore mentioned compressor kit, and mine will be a COMPLTE KIT.
I urge you all to check out the competition and then come see me.
I will give you a QUALITY KIT at an HONEST price.
www.phatcustoms.com
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 08-09-2002, 04:46 AM   #14
BaggedC10
Under construction!
BaggedC10's Avatar
The complete kit I listed would cost around $3,500. Remember, you get what you pay for. This has been my experience with AIM/Chassis Tech---Poor quality! For instance, look at the terrible welding on the new "World First" 1-5" adjustable shackles! That looks horrible! From their adds, insane shipping prices, and poorly designed products---I have nothing good to say about them!
P.S.-Their "Super C" notches are very stout though! That is one thing I would purchase from them.
Old 08-09-2002, 05:05 AM   #15
BaggedC10
Under construction!
BaggedC10's Avatar
www.phatcustoms.com
Sorry, if I upset you! I understand where you are coming from. Personally, I would rather spend the extra money and purchase a quality setup from ART---Who supplies air suspension components from commercial grade trucks, to $75,000 hot rods. There is a reason they are #1. Check this out for another happy AIM customer. The third person who replied lowered his F-150 4/6" using their LCA's and flip kit/shackles. I don't want to imagine installing an air suspension setup from them!
http://www.sporttruckworld.com/forum...c.asp?id=50479
P.S.-I am finished arguing over this, and will no longer make unfair comments towards your business.
Old 08-09-2002, 05:17 AM   #16
BaggedC10
Under construction!
BaggedC10's Avatar
..........along with many other companies including DJM, FIRESTONE, DOETSCH TECH,..........
Now, these are all excellent companies. Including Firestone............
Old 08-09-2002, 02:31 PM   #17
jay-dawg
chevelito
jay-dawg's Avatar
I read this and was like wohoo i'm in ....then I read this
cheaper
then I was like aww shucks.
jay
NSANE....I would like to do a bare bones install with bags on my ground up resto. I am going to need bags for the front and back. Do I need any special brackets? I can pretty much get the 1/2 inch lines and fittings here locally. I'm looking to just get the suspension together and get the lift and drop from my home compressor via a bulkhead connected to a manual switch paddle. I probably only need f/b or maybe I can just use a one needle guage paddle for up and down doing the resto. Can you shoot me a quote for the bags and anything (ie brackets) that I may also need?
thanks,
jay
Old 08-09-2002, 02:56 PM   #18
jay-dawg
chevelito
jay-dawg's Avatar
never mind....its all on your website.
jay
NSANE...what do you recommend for bags 2500 or 2600? I have coils in the rear.
thanks,
jay
Old 08-09-2002, 08:45 PM   #19
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Thumbs up
I run 2600# front and 2500# rear.
LowC10, I wasn't arguing with you simply arguing the facts. I am a smart enough person to know that you can't please every customer every time. I am sure the other company you mentioned has had thier fair share of upset customers, it's all in how it is handled to make the customer happy and a repeat buyer.
I stated that I consider this board my extended family, and that includes you too. Welcome aboard!
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 08-09-2002, 11:40 PM   #20
Dropped67step
Gearhead since birth
Thumbs up
Nsane If you can get a kit togeather for around 400-500 dollars i would be all over that I just cant spend the 850 you shot me the other day so if you get a kit for 4-500 let me know and I will send the cash I dont need the lines I can get that from work I work on deisel's so I run air line everyday I as so already have a tank thanks B.
Dropped67step is offline   Reply With Quote
Old 08-10-2002, 12:19 AM   #21
PushinPebbles
My dad's 68
i personaly think that AIR RIDE TECH. is a bunch of B/S..................................the under do alot of stuff............and u need to study ur truck and figure out what ur gonna do w/ it before u go and spend 2,500.00 - 3,500.00 for kit...........................................why buy a "kit" when u can make it and be much more prouder?
Jack M.
Dad's truck
(hydros)
Old 08-10-2002, 12:54 AM   #22
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks for being kind. You could have ripped on me, but instead you responded in a mature manner. That is good business practice! I have heard of one or two cases where a ART ShockWave has broken---They replaced it free of charge, obviously. Anyways, thanks for being kind!
Old 08-10-2002, 01:20 AM   #23
BaggedC10
Under construction!
BaggedC10's Avatar
It's all in the name---ART is a company that bases their products on ride/handling. If you want lift, purchase an AirLift setup. My point: ART manufactures the BEST components that are designed for your application. Not 1 size fits all. There is nothing wrong with a kit that is 100% bolt-on/weld-in. Plus, you are guranteed years of trouble-free operation from ART. They install their components on test mule vehicles, and evaluate them for many thousands of miles---In many conditions. They continue to improve, and the customer is reassured a reliable setup. I will not continue to argue over this!
Old 08-11-2002, 12:58 AM   #24
cali_surfer
cali_surfer's Avatar
I'm interested in bagging my truck as well. I have a '69 LWB coil rear truck. Is the trailing arm setup fine to use with airbags? I see all the talk of 4 links and stuff and it makes my wallet want to run and hide. I don't really want to lay the frame...... I just want something adjustable like airbags provide.
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 08-11-2002, 01:23 AM   #25
PushinPebbles
My dad's 68
I stated that I consider this board my extended family, and that includes you too. Welcome aboard! -------------damn dude u are a businessman......................u handled that smooth as silk........................................i dont want to argue over this deal but...........I love to create stuff no one else has.......................i am much more prouder of my setup then i would ever be w/ a "kit"...................................lets put this to a end...................i have my opinions and u have urs.... and i dont want to insult that in any manner what so ever........................hey atleast we can lay frame together
P.S. Nsane i am very impressed on how u handled this manner, for that u get a "at a boy!" and my business
Jack M.
Dad's truck
(hydros)
