Old 04-25-2006, 11:49 PM   #1
tx69gmc
1969 GMC SWB Rear End swap in DFW???
Hey all-
I am wanting to potentially swap the rear end in my 69 GMC SWB. Is it correct that I can use anything from 73-87 due to the fact that my truck is already set up with leaf springs. Posi or locker would be nice as well. I am going to be converting to 700R4 as well so what ratio is recommened for mild performance and good streetability? Thanks
tx69gmc is offline   Reply With Quote
Old 04-26-2006, 12:01 AM   #2
wibilly
wibilly's Avatar
Re: 1969 GMC SWB Rear End swap in DFW???
from what i unerstand front axels bolt in rears the spring perches must be relocated as far as ratio i wouldn't want cruse rpm in overdrive to be less than 2000 rpm and if using a higher than stock stall converteri would be sure and keep cruse rpm atleast 200 rpm above stall speed
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-26-2006, 12:45 AM   #3
rauto13
saving one more
rauto13's Avatar
I have 3.73 gears in a posi with a 700R4. My RPM at 70 mph is 2400 RPM. I personally think it is an ideal cruise RPM.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 04-26-2006, 05:13 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yeah, you don't want to go under 2000 RPM for cruise speed. 2200 - 2400 is ideal.
If you get a lock up converter, then stall speed isn't nearly as important since it'll go into lock up and there will be 0% slippage.
