04-26-2006, 09:17 AM | #1 |
Lowering a`72,Cheap
I`m building two shortbeds,one mild and one wild.The`72 will be mild and a budget rod mostly built from parts on hand.Since it already has discs in front,I`m thinking of doing a 4-spring drop.How low can I go and still have a suspension and not max-out the alignment?I feel drop spindles are the first step in doing it right,but want to skip that if I can.Save the money for the`67 GMC pro-street.
04-26-2006, 10:08 AM | #2 |
Keepin an eye out
Re: Lowering a`72,Cheap
I wouldnt go more tha 3" in the front and 5" in the rear.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
04-26-2006, 10:26 AM | #3 |
5 in the rear requires a c-notch though, i think that a 4" drop in the rear is the most without a c-notch. id go 3/4 or 2/4 if you dont want to notch the frame.
04-26-2006, 10:32 AM | #4 |
67 is sold
04-26-2006, 10:48 AM | #5 |
Keepin an eye out
Yup, im running the 3-5 w/ no problems.
04-26-2006, 01:33 PM | #6 |
67-72 Addict!
Tim, my truck has 1.25 coils cut from the front and it lowered it about 2.75". Handles great too! The rear has new 4" drop coils.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-26-2006, 03:22 PM | #7 |
Boraxman I have a 3/4 now and would like to go lower in the rear. But if I measure my truck is level if you go 3/5 did you compensate with tire size? Or is your level at 3/5?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
