Help please SBC swp pulley set up
I intend on first running a manual steering box on my 72 2wd sbc swp with no AC or AIR. Then when more money makes its way in to my pocket I want to got with power steering. Does any one have a picture of both of these pulley set ups and a description of what pulleys are needed and can be used from the first setup to the next? I thought i read that the power steering pump is just an add on to the crank pulley. Is that correct?
![]() ![]() Last edited by stynchrr; 04-26-2006 at 01:38 PM. |
Re: SBC swp pulley set up
Any help with where the belts are routed would help too. Thanks in advance. Tim
![]() Join Date: Feb 2004
ttt
its all about the +6 inches
Your best bet is to get them all off of one truck/vehicle, or a couple that are set up the EXACT same way. Once you start mixing and matching, things get real stupid real fast.
If possable, i would get all the stuff you WILL need, and then add it as needed. |
I couldn't copy the pic but here is the link, maybe it will help.
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=3
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
![]() Join Date: Feb 2001
This is a keyway pump from an older Impala. The top outside bracket is home made but works ok. Pretty simple actually.
Please excuse the black wire looms, lots of work to do under there in the next weeks or so. Last edited by Mudder; 04-26-2006 at 03:40 PM. |
So a two grove crank pulley for a short pump and and single grove pump pulley and i should be good to go? I have the alt bracket for the driver side.
One more question when you look at like jegs or summit is the only difference in crank pullies the short and long pump and the number of grooves? Thanks Tim |
Basically yes. Long or short pump and how many groves do ya want. There are two kinds of powers steering pumps. A pressed on pulley and a keyway pulley. You really need an old pump with the brackets on it. I'm thinking there are 3. Two brackets for the alt.
Thanks I will see if I have any luck at the yard to get what i need.
