Old 04-26-2006, 01:14 PM   #1
troy destroy
troy destroy's Avatar
power steering pump noisy
after my power steering upgrade i get a lot of pump noise when turning the wheel. sounds like the fluid is low but its not. any ideas? i would hate to burn up this new pump/box. Install was done awhile back but still getting the noise.
thanks in advance
Troy Destroy / Dallas,Tx
1963 Chevy C-10 SWB stepside
http://img.photobucket.com/albums/v6...ruck/oldie.jpg
troy destroy is offline   Reply With Quote
Old 04-26-2006, 02:40 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: power steering pump noisy
Is the belt slipping?
dennislbrooks is offline   Reply With Quote
Old 04-26-2006, 03:32 PM   #3
troy destroy
nope.
Old 04-26-2006, 04:32 PM   #4
dennislbrooks
have you bled all the air out?
Old 04-26-2006, 08:09 PM   #5
rodnok1
rodnok1's Avatar
Need to bleed the air out of the system. Jack the truck up, with the engine running turn the steering wheel from lock to lock several times slowly, checking the fluid. You may have to do it several times to get air out. When you're checking the fluid look for alot of bubbles, when you have the air out the fluid doesn't have bubbles. With truck back on ground do the same. That should do it. Some vehicles are a real pain to get air out of.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-27-2006, 10:17 AM   #6
troy destroy
rodnok1, that sounds like what i needed. thanks for the instructions on it.
