Old 04-26-2006, 02:05 PM   #1
ChevyTough
ChevyTough's Avatar
Bought 3 engine blocks - little help please!
I just bought 3 engine blocks yesterday at an auction. I looked them up on Mortec.com and got the following.
Here's the numbers off of them:
3979014 - I think I read it wrong and that 9 should have been a 0.
3970010
3959532
The first is a 350(good) if that 9 is actually a 0.
The second says it could be a 302, 327, or a 350. How do I tell which it is?
The third is a 283. Can this be built to make decent HP? Is it the same block as the 327? I don't know anything about 283's.
Thanks a bunch!
ChevyTough is offline   Reply With Quote
Old 04-26-2006, 02:15 PM   #2
Myself
Re: Bought 3 engine blocks - little help please!
If you'll post the stamped in numbers off the front pad on the block I can help you.
Myself is offline   Reply With Quote
Old 04-26-2006, 02:19 PM   #3
ChevyTough
ChevyTough's Avatar
Hmm....didn't get those. I'll go see if I can get 'em real quick.
72 Chevy C10 longbed 350/350
86 Chevy K10 short-stepside, daily driver
63 Galaxie 2 door sedan 260/3 speed - basket case
72 Chevy C10 longbed - parts (good box and A/C cab)
70 Chevy C10 longbed - parts (decent box)
66 El Camino 327/Powerglide (extreme rust)
61 Bel Air, no drivetrain, sittin' in the pasture
71 F250, 72 F150, 70 F100 - parts
Old 04-26-2006, 03:26 PM   #4
ChevyTough
ChevyTough's Avatar
Okay, I must be blind. Where are the numbers you're looking for at? And are they raised or stamped?
Old 04-26-2006, 03:35 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
They are stamped into a small pad just in front of the passenger side head. ( The opposite corner from the engine number at the back of the driver side head)
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-26-2006, 03:35 PM   #6
pound41
On the front side passenger side deck. Where the head would mount there will be an extra flat pad. On that pad would be a code. For instance the the block that could be a 350/302/327. You would see something like DZ1708. DZ is the code for 302 so that with the block # would mean a 302, other number are month/date etc. Our truck blocks I think have 3 letters all starting with T I think. Don't quote me its been a while since I have looked at that stuff. But thats a ballpark view
pound41 is offline   Reply With Quote
Old 04-26-2006, 03:37 PM   #7
ChevyTough
ChevyTough's Avatar
Ohh, okay. Thanks guys. I never realized there was a number there. I'll go look again.
I'll post back in 10 or 20 minutes.
Old 04-26-2006, 03:59 PM   #8
ChevyTough
ChevyTough's Avatar
Okay, the first one didn't have a number. It looks like the surface was machined and that took the number off. CRAP.
The second one looked like CE0A425. With 42 a little to the right.
The third looked like CE0A188. With 96 a little off to the right.
Old 04-26-2006, 05:15 PM   #9
Myself
Those numbers don't seem right to me. Possibly partial VIN numbers or something. It should look something like this...F0328TKM.
Old 04-26-2006, 06:15 PM   #10
Berryman69
Are we having fun yet?
Hope this helps....
These numbers are block casting numbers.
3970014 -1970-73 350ci LA built Camaro
3970010 -1969-79 350ci car, truck, Vette
3959532 - 1956-67 283ci
This is according to http://www.nastyz28.com/sbchevy/sblock.html#cdate
'69 GMC - my driver 292, New Process 435
'01 Camry - family car
'04 John Deere
Berryman69 is offline   Reply With Quote
Old 04-26-2006, 07:10 PM   #11
ChevyTough
ChevyTough's Avatar
How do you know the 3970010 is a 350 and not a 327?
I also read on some website that the CE meant it was a crate engine.
Old 04-26-2006, 07:33 PM   #12
Blue85
Oilfield Trash
Blue85's Avatar
Measuring the bore diameter should tell you.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-26-2006, 08:24 PM   #13
Berryman69
I have a block with the same casting number and it came from a wrecked '68 vette. Mine has the four bolt mains. As posted earlier check out this website. The page that opens gives the info.
George
'04 John Deere
Old 04-26-2006, 10:56 PM   #14
ChevyTough
ChevyTough's Avatar
Alright, thanks a lot everyone! This really helped out a lot. Now I just need to tear the bottom end out of both 350's and see if they're 2 or 4 bolt mains.
What is best to pour in cylinders to loosen up the pistons? I've heard either Coca Cola or diesel will work.
Old 04-26-2006, 10:56 PM   #15
boogie67
boogie67's Avatar
So did our trucks with that #3970010 come with 4 bolt mains?I just pulled one out of a 71 and it has 4 bolt mains on it.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 04-27-2006, 06:33 AM   #16
junkyardjohn
junkyardjohn's Avatar
DIDN'T ALL 67-72 TRUCKS COME WITH A 4 BOLT MAIN?? IT SEEMS THAT EVERYONE I'VE PULLED APART, OVER THE YEARS HAS BEEN A 4/BOLT. I JUST ASSUMED THAT THEY ALL CAME FROM THE FACTORY THAT WAY. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-27-2006, 10:55 AM   #17
ChevyTough
ChevyTough's Avatar
I'm pretty sure all the 67-72 truck 350's had 4 bolt mains.
Old 04-27-2006, 11:01 AM   #18
Medicanman71
Medicanman71's Avatar
I'm no motor head but i was under the assumption that the truck 350s from 67-72 were 4 bolts...
Medicanman71 is offline   Reply With Quote
Old 04-27-2006, 12:18 PM   #19
Voodooracer
Voodooracer's Avatar
The 283 is a fun motor. Not much TQ but lots of power and high RPM's. The 283 I built 10 yrs ago was the funniest motor in a 68 Longbed and a 4 speed. If you want fun. build the 283.
Voodooracer is offline   Reply With Quote
Old 04-27-2006, 12:46 PM   #20
Chevrolet4x4s
Chevrolet4x4s's Avatar
Both are 4.00'' bore
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 04-27-2006, 12:52 PM   #21
Chevrolet4x4s
PB BLASTER might also work.Also have heard that drilling out a spark plug adapting an air hose fitting to it threading it in and hooking up high pressure air to it will break a stuck engine loose.
Shane
Member#20327
Old 04-27-2006, 01:02 PM   #22
mrjs80
Marvins "Mystery oil"
mrjs80 is offline   Reply With Quote
Old 04-27-2006, 04:03 PM   #23
junkyardjohn
I THINK YOU MEAN "MARVELS MYSTERY OIL" JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 04-27-2006, 10:38 PM   #24
Chevrolet4x4s
Yeah that stuff is a mechanical cure all
Shane
Member#20327
