which would be easier?
switching the head gaskets IN the truck, (87 jimmy 2.8, v6) or pulling the whole engine and putting in another one, then having the old one to look at/rebuild. it was a strong runner till the head gasket blew. keep in mind, i have a bad back and will only have limited help, with an engine hoist.
Re: which would be easier?
I think they'll take about the same time in doing but, I would replace the head gasket instead.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 Last edited by oscareltemblo; 04-27-2006 at 12:34 AM. |
i would replace the head gaskets if the engine is good shape otherwise
IF it is a 4x4 you need to pull the body mount and lift the body 4-6" to get the engine out ![]() ![]() the 2wd ones are easier you only need to pull the hood off |
thanks gents. i guess i will try pulling the engine, cant spend too much time bent over the fenders.
