Name that transmission...inside please
I posted a few weeks ago about my transmission in my 84 Silverado 1/2 ton 4x4, 350. I have pictures now, can anyone help?
needin' money
Re: Name that transmission...inside please
russell should know
SWB Stands for Short Wide Bed Last edited by 82c10; 04-27-2006 at 06:27 PM. |
Good, my linkage is REALLY sloppy too, I think i'm gonna rebuild it, but just need to know what i'm working with
Chris
Well that bellhousing is an old one. I got one like it from an old straight 6 chevy in a truck. As for tranny I'm nto sure other then it's a 4 speed. Maybe muncie? I got a saginaw and it looks alot different.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
I would say that is the GM version of a New Process A833. If it is a four speed, has overdrive, and a Hurst shifter, that would confirm my guess.
Hurst can rebuild your shifter and I think they still have the rubber bushings for the shift linkage. |
#6 | |
On a budget like Fred Sanford
I'll second the A833 vote. That doesn't look anything like the m22 muncie in my truck.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
I'm pretty sure its not a muncie. It IS a four speed, I dont believe its a hurst shifter unless its been changed out, it doen not have a low first gear either. I will look for the A833 online to see if I can find anything else, thanks. Any other suggestions would be great!!
If it is a factory Hurst shifter it will only say Hurst on the face outside face of the shifter body, the linkages in the pics look like a Hurst shifter.
I know that this is an old post and I am wondering if you have figured out what you were going to do with this truck ?
