Old 07-29-2002, 11:20 AM   #1
stomper
Junior Member
stomper's Avatar
stubborn steering arm
How do I get this @#%*# steering arm off my '86 K20? Got the tie rod out and 3 nuts off. Soaked in liquid wrench but the wedge locks on the studs are not loosening. Got the rest of the lift kit on but this is a bugger!
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 07-29-2002, 11:27 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Had the same problem installing a lift on a 85 K5. You need to strike the steering arm on the side with a BIG HAMMER. On mine it took a couple sharp hits then it popped off. Good luck.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-30-2002, 01:57 AM   #3
Dropped67step
Gearhead since birth
You are going to have to knock the crap out of it 2 hours and three hammer handels later mine came loose Bruce.
Dropped67step is offline   Reply With Quote
Old 07-30-2002, 02:19 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Mine took a BFG and some serious blows to knock it off.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-31-2002, 01:27 AM   #5
stomper
Junior Member
stomper's Avatar
Working on it 2 days. Now I'm swingin' an 8lb sledge with a 4' handle. Am I doing something wrong? I backed the 3 nuts way off and took the tie rod out. Something's gonna break! Yikes!
Bouncytruck, I see you're my neighbor.
Old 07-31-2002, 02:15 AM   #6
Dropped67step
Thumbs up
are you hitting it on top or on bottom? use plenty of some kind of w-d40 also hit it on the sides I used a chisel on the cone lock nuts to try and turn them a little it is a ***** but very well worth changeing becouse bump-steer can kill. Good luck and I will ask a couple friends in the mooring what they did to get theres off. But you are going to have to try to turn thoose Cone locks a little mine had little goves in the top that helped turn them . later B.
Old 08-01-2002, 01:44 AM   #7
stomper
Junior Member
stomper's Avatar
I got it! I got it! The neighbors came out to see what all the celebrating and yelling was about. Burnzomatic and more hammering. I think I ruined the upper ball joint - it's got play in it now - S**t :mad
Old 08-02-2002, 01:00 AM   #8
Dropped67step
Talking
Congats man good job !!!!!!!!!!!!!!
