Old 04-28-2006, 09:02 AM   #1
52chevy
52chevy's Avatar
Rear End 1952
ok i am putting a four link rear suspension on a 52 chevy pick-up (3100) and i need to know the pinion angle before i can finish it. can you email me at marlocromwell@yahoo.ca if you know this. i dont really check this forum to often so it woudl be better if you could email me thansk.
52chevy is offline   Reply With Quote
Old 04-28-2006, 07:37 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear End 1952
Start at 0 degrees. you'll have to adjust it later. Pinion angle is relative to the drive shaft and engine angle. You need all 3 in place to get the final angle.
http://www.vibratesoftware.com/html_...aft_Angles.htm this is the best site I've seen to describe the pinion and drive shaft angle relationship and how to make the adjustments, how to properly measure the angle so you get it where you need it.
I'd email you but I'm not aloud to email strangers in other countries.
dwcsr is offline   Reply With Quote
