07-29-2002, 01:47 PM | #1 |
cracker
HEI Vacumm advance
I was reading the post on hei advance and realize i have no idea what all these degrees andall mean, i now about dwel when dealing with points, but im confused so here is my question, if i have an HEI ignition with vacumm advance, do i need to worry about anything inside to do with springs or anything? thanks
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Harry John Albert III located in Phoenix, AZ 1972 GMC JIMMY, 1969 lwb Chevy Frame, 1999 bmw k1200 ltc 1992 Kawasaki concours 1991 bmw k75 1973 cortez motorhome |
07-29-2002, 03:21 PM | #2 |
Fabricate till you "puke"
if you are doing a recurve ,pick up a crane vac advance kit, it will also have several springs for the mecanical advance. Just read through the inst with the kit, & it will set up pretty good for a relatively stock engine. good luck.....Al
