Old 04-28-2006, 05:18 PM   #1
asickber
Tune-up after sitting for awhile
I plan on getting insurance on my truck this summer. It has been sitting with the occaisonal start up for quite awhile. What do you guys recommend for a tune-up?
asickber is offline   Reply With Quote
Old 04-30-2006, 05:01 PM   #2
asickber
Re: Tune-up after sitting for awhile
Anybody got any advice for me besides the basics?
Old 04-30-2006, 08:08 PM   #3
matthufham
can we have some info on your situation? how did what kind of engine run when it did? ragged or smooth? what's on the motor and what has been done to it?
matthufham is offline   Reply With Quote
Old 04-30-2006, 09:19 PM   #4
asickber
It has been sitting with the occaisional start up and run for about 6 years. It ran good and smooth when parked. It has a 402 that was rebuilt about 10 years ago. The motor doesn't have any performance parts, it's stock. Now when started it takes awhile until it idles without having to give it gas. And when given a lot of gas it sputters and gets ready to die. Do I just need to adjust the carb?
Old 04-30-2006, 10:50 PM   #5
matthufham
might change the spark plugs, maybe see if the ends of the spark plug wires have corroded or anything. clean the gas tank out and check out the filter on the carb or if you have an inline fuel filter, check that or replace it. check if anything's in the air filtration system, and maybe change the motor oil with a new filter. that should make it run pretty efficiently.
Old 04-30-2006, 11:04 PM   #6
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I would crawl around underneath with a grease gun also.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
