Just A Tool Hand
Where these came from?
These will fit our trucks! But what did they come off of? Trying to find, these will bolt in my 455 to the frame. Please help!
:hit: |
Re: Where these came from?
no clue
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
They look like 73 and newer Chevy truck engine brackets. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Member #1049
Those are 73 - 80 Chevy diesel mounts which is actually a 350 Olds engine..
Just A Tool Hand
Do they have to be diesel mounts or can they just be gas. I found some that look like them this afternoon, but they were in a 74' that orig. had a 454 then ended with a 350.
:hit: |
I believe all those are the same in those trucks.I`ve never heard of anyone swapping diesel/vise-versa or SBC to BBC/vise-versa needing to change towers.
Fabricate till you "puke"
The stands are for sure 73-up, as already mentioned. The pads LOOK much like the deisel pcs, but are not. I have a set on the shed wall from the 455 Olds days, that I personally pulled from a deisel truck. My guess is somebody did an engine swap, & used what car mounts ( steel pads) that they had available, & the mounts to match. The stands are not a direct bolt in for the older trucks, but you can make em work. The A body (cutlass), & the deisel trucks use the same rubber mounts on the block, so if you are planting an Olds engine, go for the cutlass motor mounts, use the truck stand(redrill or weld down), & if the pads fit, use em(also weld down). The deisel pcs DO indeed make the Olds swap a little easier, but not an absolute "must have". When you say 455, it could be Buick or Poncho also......that I cant help with, but I have done the Olds & will say it was badazz
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Just A Tool Hand
This will be my fisrt major transaction, so any help will be very very appreciative!!!
:hit: |
its all about the +6 inches
That's what I used on the caddy swap, a very nice piece to install oddball stuff.
its a hammer..... or advertised at a garrage sale.... high performance intake slides.... adds 20 hp..... no warr.
Does anybody know where i can purchase these mounts. Thanks i really need them i am trying to mount a 455 to thanks frank
