Old 04-29-2006, 01:03 PM   #1
tony carr
tony carr's Avatar
does anybody know this part ?
I just took this pic and need to find out what part this is ? the part mounts the lower portion of the front fenders to the front of the cab --- tony------ I can't get the pics form cardomain is the part called Lower hinge bracket ? need help so I can order it ...
1956 chevy big window swb
http://www.cardomain.com/ride/2333154
tony carr is offline   Reply With Quote
Old 04-29-2006, 02:26 PM   #2
BOHICA
BOHICA's Avatar
Re: does anybody know this part ?
Sounds like the fender brace.
BOHICA is offline   Reply With Quote
Old 04-29-2006, 03:41 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
If its part of the cab I think you are looking for an outer lower pillar pocket. It has a bolt hole for the hinge. There is an inner and an outer.
If its part of the fender its the fender brace there is a left or right on bot parts
dwcsr is offline   Reply With Quote
Old 04-29-2006, 05:22 PM   #4
tony carr
tony carr's Avatar
I think that you are right . I look at www.lmctruck .com and found that it the hinge pillar repair panel.... www.ccgtrucks.com calls it lower outer pillar section
and www.grumpystruckparts.com calls it front hinge pillar repair
thanks for the help . I would have posted the pic but I have not found out how to transfer from cardomain.com
Old 04-29-2006, 08:37 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I just realized that there is a fender re-inforcement bracket that the bolt goes thru into the fender brace to secure the lower fender to the cab. That is a part that you may have to make. I haven't seem them anywhere. It welds to the bottom of the lower outer pillar pocket.
Old 04-30-2006, 02:23 PM   #6
tony carr
tony carr's Avatar
you know I think that you are right the fender does have a bolt on the bottom and it bolts to the lower pillar It is going to sux if I have to make it just might have to cut the left side off in order to make the right .. Hey if I make this part does anybody need one ? might as well make like 5 of each side
Old 04-30-2006, 02:50 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
I need 2. It supprises me that no one makes these. If you have a rotted pillar pocket usually the bracket is gone as well.
Old 04-30-2006, 06:37 PM   #8
john
member #16
john's Avatar
LMC shows a pillar repair piece that looks like it has the ear for the fender bolt. #4 at top of page.
john is offline   Reply With Quote
Old 04-30-2006, 09:07 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
were looking for 55 - 59. thats for 67 - 72
Old 05-04-2006, 07:38 PM   #10
tony carr
tony carr's Avatar
cool as soon as I cut the left one off . I will make some and let you all know
