Old 04-30-2006, 12:19 AM   #1
67Mach1
67Mach1's Avatar
Front Cross Member swap? what years
What years of chevy trucks will swap over for the 67-70 Disc brake conversions.
I have heard up to 87.
Are the Vans both Chevy and GMC also included in this "able to swap" list.
Have a line on a van that I can use the body for storage and front cross member fore Disc brakes if it works out.
Thanks,
Thomas
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 04-30-2006, 01:21 PM   #2
saxmo
saxmo's Avatar
Re: Front Cross Member swap? what years
I, personally, have done the front swap with crossmember from a 1986 model truck, so I know the 73-87 stuff will work. I believe that the van stuff will work, but the rotors may be thicker (just keep in mind when getting parts). Do not quote me on the van though...
2004 Corvette Coupe Black LS1 (daily driver)
1973 Ford Bronco (resto/mod @ 95%)
1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said)
1997 Ford F150 4.2L 500k+ miles (trash hauler)
2011 Nissan Juke (wife's daily driver)
1943 Ford GPW WWII jeep (waiting its' turn)
saxmo is offline   Reply With Quote
Old 04-30-2006, 02:07 PM   #3
Don Brace
Active Member
My 69 has the disc brakes from a96 Chevy van. I was not able to use the cross member not the sway bar because they were too wide. It was an easy swap.
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 04-30-2006, 05:46 PM   #4
Geezer
Geezer's Avatar
I think you can go up to 87 with a pu or 91 with a sub. I'm using an 88 sub crossmember, brakes, and steering box. I had to redrill 4 holes in the sides of the frame. 2 were 1/2 a hole off and 2 were a 1/2 inch off. I bolted every thing up that would fit then drilled through the frame.
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
