Need front disc pics
We did the drum to disc/drop conversion and now the brake hose off the caliper hits prematurely on the crossmember... is this normal? anyone have any pics of their setup? maybe we installed something incorrectly
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
![]() Join Date: Jun 2002
Re: Need front disc pics
Hopefuly these will help ! It's a complete 72 disc setup bolted up to my 68 frame. Early Classic drop spindles, Brake lines are s/s hard tube and s/s braided line from Inline Tube. Brake calipers are OEM.
If you need another angle, just let me know and i'll run out to the shop and snap it !
![]() click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide Last edited by Bowtie468; 06-14-2006 at 04:43 PM. |
i too have a 68 and my hardlines run behind the front axle member ( if thats what its called)
![]() ![]() ![]() and how my brake lines are ran ![]() |
thanks guys... it looks like you both have them connected to the crossmember in different spots!! bowtie, your are connected in the front of the A-arm and 68... well, yours are in the same spot as mine, in the back of the A-arm... Will the hose pinch or get kinked when you turn the wheels all the way right/left?
no not even close....
whats yours look like? we need pics of yours |
Active Member
thanks for the pics guys. I am about to go through the same thing. Swapping 76 chevy discs on to my 67. My lines are behind like 68's I was worried I may have to get new lines. Looks like maybe not.
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Stock corssmembers from 71 and 72 had the brake line tabs in front, all 70 and earlier trucks had them behind.
here are a few pics... these are the regular rally wheels 15x8 4 1/2" BS, with 265/70/15 tires. It looks good if its the rightside tire turned left or leftside tire turned right, hope that makes some sense
front left, turned hard left ![]() front left, turned hard left ![]() front right, turned hard left ![]()
Nice pics
