04-30-2006, 08:05 AM | #1 |
Going for 20's got bs & tire???'s
is this the correct bs? 20x8 front 4" 20x9.5 rear 4.5? I read all the post and still not for sure. Whats the biggest tires that will work on the rear. Its a 72 fleet side,dropped spindles, blocks and bagged. Thanks for your help.
Kenneth
72 CHEYENNE 10 SUPER 468/400/3.73 |
04-30-2006, 08:58 AM | #2 |
Re: Going for 20's got bs & tire???'s
Sound right, but I would pull a wheel (make sure suspension is loaded) and measure.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-30-2006, 01:20 PM | #3 |
I hope to see many replies on this as i am about to do the same thing.
04-30-2006, 03:31 PM | #4 |
I did alot of research on this before I ordered my wheels. I just found a board members turck that had a wheels and tires that I liked and asked them. I went with a 18x8 in front with 4 1/2" bs, and 20x10 with 5" bs in the back. I havent got the wheels yet so I can comment further but thats what I did.
04-30-2006, 08:16 PM | #5 |
I posted this question twice and never got a response... I ordered my front wheels with a 4" BS, 18x8... hope they fit!!!
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
05-01-2006, 06:05 AM | #6 |
Thanks for the replies. Anyone else care to share? Please
05-01-2006, 08:30 AM | #7 |
PM Danny about his set up. It looks like he nailed it on adequate tire size & fit..... http://67-72chevytrucks.com/vboard/s...d.php?t=197866.
05-01-2006, 02:57 PM | #8 | |
LAIDOUT
05-01-2006, 06:52 PM | #9 | |
05-02-2006, 09:55 AM | #10 |
what are some sugggestions for a 20 inch front tire if i use a 295/50/20 on the rear ?
05-02-2006, 12:34 PM | #11 |
is all this applicable to a stepside?
05-02-2006, 05:11 PM | #12 | ||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-06-2006, 06:14 AM | #13 |
Thanks for the help. TTT one more time.
08-22-2008, 03:54 AM | #14 |
Think 295/50/20 would work okay with a 9" rim?
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-22-2008, 04:33 AM | #15 |
Hey guys,I am running 20 x 8 front 5 1/4 bs, 255/40/20, 20 x 10 back 5 1/4 bs,295/40/20 Toyo proxys,I do have a small billet spacer on back for my wheel plates. Thanks, Danny
08-22-2008, 06:28 AM | #16 |
67-72 Addict!
Danny, this is a good time for you to post up some pics of that sweet truck of yours! I NEVER get tired of looking at your rig
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-22-2008, 09:58 AM | #17 |
Danny, nice truck!! What size is the spacer in back? Would it change the BS if you did not have it? Thanks.
