Old 04-30-2006, 09:44 AM   #1
UGLYTRUK
New Member
Waste oil conversion, anybody done it?
I'd like to convert my 87 6.2 Sub to veggie oil. Anybody running one of the systems on the market? Two tanks?
UGLYTRUK is offline   Reply With Quote
Old 04-30-2006, 01:56 PM   #2
Re: Waste oil conversion, anybody done it?
I`m afraid to.Playin`wait and see.
Old 04-30-2006, 04:15 PM   #3
UGLYTRUK
New Member
Got deezel? I bet there's someone nearby that has already done the conversion. Usually on a Mercedes or Volks. My only concern is who's kit to use. Check these out... http://www.vegpower.com/, http://forums.biodieselnow.com/topic...07&whichpage=2, http://www.frybrid.com/forum/usercp.php?hpage=2, http://www.fattywagons.com/fwproducts.htm.
Confused? Me too... The VORMAX filter seems to be the one. Then the fuel tank issue. $$$ to build a small deezel, and where to put it? Behind rocker? Behind right rear wheel well? And fill directly from restaurant to tank thru VORMAX filter. Thereby not storing oil at home. A pain...
Old 04-30-2006, 11:04 PM   #4
kfchewj
if you make biodiesel out of the veggie oil instead of using straight veggie oil you can put the biodiesel in any diesel engine or furnace etc.
then you don't have to do any mods to the truck.
kfchewj is offline   Reply With Quote
Old 05-01-2006, 12:07 AM   #5
UGLYTRUK
New Member
Yeah, but also enjoy the novelty of running spring roll oil...
Old 05-02-2006, 01:09 PM   #6
screwballl
Tonawanda 454
screwballl's Avatar
a guy came into work yesterday doing that exact same thing, complete veggie oil from local restaraunts. He starts it and runs for a few minutes on regular diesel then switches to veggie once it has heated up. He is running a line from the coolant back to the veggie oil tank to heat it up.
Didn't go into too many details but I got the main idea behind what he is doing.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
