![]() Join Date: Feb 2004
More info -- Rotors/Spindles -- 88-91 6 lug
I saw a 97 -- 2500 - 6 lug Cheyenne yesterday -- learn something everyday.
Anyway pics show a 71/72 rotor (5 lug in pic) that does fit on a 3/4 ton LD spindle and also shown is an 88 3/4 ton LD GMC 6 lug rotor. Both take same A3 and A5 bearings and seal. I have not tried yet but I believe the 72 or 88 calipers will work with respective pads. Not sure if the 88 caliper takes the same flex hose yet either. 1/2"-20 x 1.720-1.750 with a .615/.625 diameter knurl replaces the metircs wheel studs-- one has been replaced. I could not find a 7/16 with a big enough knurl. Should still work fne on oem 6 lug wheels. The 88 spindle takes the same 6117 lower ball joint -- the 71/72 takes a 6124 upper and the 88-91 (may be others) take a 6136 upper ball joint. The outer tie rod end on the 88 spindle is a rethreaded 88 to fit a 65-70 c10. Anyone else have any info or experience on this? |
![]() Join Date: Apr 2005
Re: More info -- Rotors/Spindles -- 88-91 6 lug
I've got a nice set of 2003 suburban wheels w/tires if you need them.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
This thread has a ton of good info on conversions...
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042 |
good thread for sure-- point here is also to interchange rotors from 5 or 6 lug. I list the 3/4 ton LD spindles to use the 6136 upper -- I have not found A-arm changing necessary --- but maybe -- there are things I do not know --- 87 LD 1/2 ton 5 lugs will go on 65-72 spindles with use of correct spindle year upper and lower ball joints (6117 and 6136)---- appears near all 1/2 ton 71-91 (may be higher) use the 6117 lower ball joints --even the 3/4 ton 6 lug LD. Does anyone know if the 71/72 calipers work on a 88 3/4 ton LD spindle? I suspect it may.
#5 | |
If this is a true statement, why swap all the 88-up stuff? Why not just use the 88-up 3/4T 'LD' 6-lug rotor on the 73~87 spindle? The wheel studs will require possible changes but bearings & rotor width/diameter are the same. This would seem easier than locating the C20 3/4 ton lower arms just to use the 88-up spindles. What am I overlooking?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-30-2006 at 01:02 PM. |
I believe we are in agreement Scoti. I will pick up calipers/pads for the 72 and 88 this week to see the diff --will only purchase one pair -- hopefully the 72's as they are less expensive. Somethings ya just have to know. haha As far as the 88 spindles--just whatever is cheap easy to get at the time $10. I do not know if there are any differences between the 1/2 ton HD and 3/4 ton LD spindles -- I believe they are the same 73 up with exception of maybe the upper ball joint which both fit in the 1/2 ton 65-70 A-arms. Anyone know this not to be true?
Post back what you find out please! I’m using 88 suburban spindles and have found that the 1991, 6 lug rotors have a different rotor centerline and the calipers won’t fit using them.
If you can't drive it park it! If you can't park it milk it! |
#8 | |
Good info Geezer -- will do on the posting ---- I have a 72 5 lug on one 88 spindle and a 88 6lug on the other 88 spindle --will get a pic side by side also
Ok--agree with offset --- for sure the left one takes an 88 caliper --one on right is a 72 rotor on an 88 spindle --will see if a 72 caliper works on the right one. Looks like wheel to hub mounting surface is same height--hard to see in pics. Last edited by dennislbrooks; 04-30-2006 at 05:57 PM. |
67-72 Addict!
Dennis, after you get all this sorted out, you should start selling kits for all us 6 lug guys!. Thanks for sharing this info.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Ok-may help when trying to be scientific on the approach to be a scientist. OK --the spindles are from a 88 Chev G20 Van ---- the 72 5 lug rotors work on them with the 72 calipers and pads as shown in pic. 72 calipers are cheap even with no core.
I will pick up the pair of 88 G20 van calipers tomorrow evening to see if they work on the 88 G20 van spindles with the 88 3/4 ton LD 6 lug rotors -- I do know the 72 calipers will not work because of the offset. Stay tuned. |
Keeping this one up front as we wait for our friendly 'scientist' to complete his experiments.
#13 |
End -- More info -- Rotors/Spindles -- 88-91 6 lug
OK--- I tried the 88 G20 Calipers on the 88 G20 spindles which by the way are very near identical to 71-87 1/2 ton HD --- tie rod ends and upper ball joint may differ ---- and the 88 G20 calipers still will not work with the 88-91 3/4 ton LD 6 lug rotors. I really think as others alluded to that if you do not want to buy your 6 lug rotors from McNaughy's or similar then you need the 88 3/4 Ton LD spindles and calipers --I do not know if there would be brake line connection problem or not. 11/16 inch RH tie rod ends can be overcome if the spindles could be used at all on a 65-70. If any one comes across a 3/4 ton LD 6 lug spindle rotors and calipers take some pics or drop off at my house.
#14 |
Dennis.... Is it the bearing race location/depth (relative to the rotor surface C/L) that's different? I can only assume that's where the difference would be if they can utilize the same bearings.
#15 |
Bearing locations are fine. Machining of the lip seal is ok also. Just like Geezer said above the rotor is offset about 1/2 inch outward. I did have a caliper for an 88 3/4 ton LD and it is longer/larger than a 72 1/2 ton and a 88 G20. Next time I walk a junk yard I will look for some of these 3/4 LD parts.
#16 |
![]() Join Date: Nov 2001
Guys... I already went down this road (I think)
I work at a Auto Parts Warehouse. I was thinking a 88-92 3/4ton LD rotor would go on a 73-87 spindle. I found the offset (where the inner race rode on the spindle) was too far outboard. But, I see your talking about a "van" rotor. I can look at the diamensions of that today. I do know, the adjuster sleeve on a 71-87 versus 88-92 are the same thread. I used the 88-92 LD 3/4ton spindle (88-92 1/2ton HD is same, only if 1-1/4 rotor thickness, but still need to use 3/4ton LD 6 lug rotor), caliper, rotor, & outer tie rod end. I did this so that I could get the aftermarket 2" lowering spindle. Now, if you do use the 88-92 spindle, you need to use a 63-87 3/4ton lower control arm as the ball joint diameter is the same. you can use your 1/2 ton upper with a 88-92 ball joint. I see that you are looking at slightly different applicated stuff so, I will help you research this stuff. Even though I'm complete in my front end build. I'm always up for new knowledge. You can email me direct at bryan@sturdevants.com and I can look at the parts spec's books to give you diamensions. So, email me the application on anything your thinking of using.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 05-02-2006 at 08:14 AM. |
#17 |
67 cst swb -- knowledge is good. I used a G20 van spindle which accepts the 71/72 5 lug rotor and caliper. The rotor I used was an 88 GMC 3/4 Ton LD -- and I agree with what you say. Unless you have the matching spindles installed--stay away from the 6 lug 3/4 ton LD rotors for use on 71-87 spindles.
#18 |
Dennis - I have one DUMB question - what is 3/4LD? What does LD stand for? I love this thread where we are trying to save money and adapt other parts to these old trucks.
Listen to this guy. He is a genius at adapting parts. 6 lug rotors, hydraboost, and probably other things we don't even know about yet. Keep thinking - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#19 |
I learn as much from you guys -- LD means Light Duty --- take a look at rockauto.com for an 88-91 GMC C2500 2wd 350 eng -- brake/wheels/hubs - then rotors 7200#'s fronts
I saw 97 Cheyenne C2500 that had 6 lugs also -- and not a 4wd Last edited by dennislbrooks; 05-02-2006 at 01:39 PM. |
#20 |
Can somebody put this in the FAQ section??
I love this site!!! ![]()
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#21 |
Bob Moore, sometimes my experiments have a downside... This is an ironicle joke -- but if any one needs 2 new 88 GMC 3/4 ton 6 lug or equiv rotors ----- let me know....... 8-) or drop off a pair of correct spindles.
