Used to have a truck
Long Chevrolet oil filter
What is the fram number of the long truck style heavy duty oil filter. You know, the 10-12 inch long screw on one. The guy at the parts store thinks I'm nuts.
No truck :-( |
The PH-35 is the longest i have ever seen in a Fram "screw-on".......about 4-5 inches long....never seen one longer than that
![]() I use Delco filters, so not totally sure on the Fram part number..... Last edited by Shane; 07-29-2002 at 04:45 PM. |
huh?
![]() Join Date: May 2000
I have no idea about a fram filter, but racedvl gets the extra capacity filters for his vehicles. You might just shoot him a PM, and ask for the part number.
TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Suburbans RULE!
I use the "long" filters on my truck. They are about 9-10 inches long and hold almost 2 quarts.
Fram = PH373 AC = PF932 Wix = 51794 (the one I use) There is plenty of ground clearance because I have a 4X4. The 2wd guys may not. ![]()
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
![]() Join Date: Jun 2000
The 327 I bought out of a '68 2wd had one of those on it--has a bolt going through the middle. I thought it was oooold (looked it) and figured they probably didn't make'em like that anymore. Cool.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
Currently Blazerless
I use the ph373 on my truck, you can see how close the filter is to my headers, using the ph35 made it difficult to change and I think the longer filter should help cool the oil when this close to headers.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
HOLY SMOKES!!!! that thing is HUGE......thanks for posting a pic....never seen one of those.....thats what ya gotta love about this board, learning something new everyday.
its all about the +6 inches
They used to be common on fleets and emergency vehicles.
Not the nightly winner
HASTINGS FILTER NO.226 IS THE 2QUT.
WIX NO.IS 51794 2QUT. I CAN"T REMEMBER A/C NO. I USEUM ON ALL MY V8s.
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
Formerly yellow72custom
I was gonna start using those filters...until i saw that the 2qt. Wix filter costs $10. I change my oil about every 2-3 thousand miles anyway so i really don't need one.
gmcblu, the filter you are talking about with the bolt going through it is a cartridge-type oil filter. There is a filter inside of that, and you replace it. You can still get a Wix filter for one of those too.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
![]() Join Date: Jul 2001
Probably not used much any more or may not even be available but on my ' 65 Impala SS Sport Coupe I HAD (key word there HAD) I used a Fram CH200PL which went into a cannister with a thru bolt and used a replaceable ring seal. Thought when they came out with the spin on filter that it was a good improvement. Went out and bought the spin on retro-fit kit as soon as it was available. Seems as if that CH200PL # is burned into my brain.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
That is the longest filter I ever saw.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines |
#13 |
I ended up getting the NAPA version of that filter which is a couple of inches shorter it seems although they cross reference it to a PH 373. I dont think I could clear my headers with a full length PH 373. Ive used the 373 on a few camaros I had in the past. Their nice when you are using a full flow oil filter adaptor as there is less of a tendency to blow them up when the oil is cold and you are using a high pressure/ hi volume pump. My oil pressure is so high (110 lbs) now when cold I dont dare use a full flow adaptor.
actually I just checked it. The ph373 is only a quarter inch longer. Think I'll use that next time.
No truck :-( Last edited by mikep; 07-29-2002 at 10:48 PM. |
#14 |
That Thing is HUGE, i never seen one,i guess you learn something new everyday...
#15 |
Old Skool Club
![]() Join Date: Jun 2001
If you are using the cartridge-type, be sure that the o-ring on the adapter is seated properly when you service it. If the o-ring isn't changed with each filter change, it is possible that it can blow out of the groove when the engine is cold, or anytime for that matter. Just be sure it is where it belongs....don't assume that it is good.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#16 |
![]() Join Date: Dec 1999
Wow! That Bad Boy is Huge! First one I have ever seen.
#17 |
newly minted old timer
make sence to me, i have always thought they should spend more time on building better filter and forget all the fancy oil.
if you change your oil every 3-5 k miles like you should you dont need to worry about oil break down, but you do need to worry about particulates IN the oil. thats were these big ass nice filters come into play. even that fancy oil has the same particulats doing the same dammage. so to me.. use the money you are wasting one fancey sythitic oil and use it on filters... but then again, i could be wrong.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
#18 |
I do use all those on all my trucks. And as already said, the hastings # is LF226.
#19 |
Registered Cruiser
Those must flow very well. I'm going to look for one the next time I change my oil.
I intend to live forever. So far, so good. |
