Eaton Pinion Nut wont budge :-( Ideas??
Hi All,
Well my new oil seal arrived to stop my pinion leaking, downside is I have tried for 3 hours to remove the pinion nut with no luck ![]() I tried my air wrench, 3foot long breaker bar, even had this on with an extra tube still no luck! Also but the bar on and tried to push the burb so the axle might undo it. Im really struggling now as I need to get it fixed, May be a dumb question...is it a LH or RH thread? Cheers
Dave B 69 Suburban 3 Door 32 Pick-up ![]() |
DONT TRY THIS AT HOME!
Re: Eaton Pinion Nut wont budge :-( Ideas??
its a regular thread, just real tight, hasnt been off in 30 plus years. You need to shock it hard to get it broke loose, it's hard to get leverage when you are under it, but remember, you can pull harder than you can push, so make sure you are on the correct side of it and pull down with a cheater pipe on your breaker bar. you may have to jack up one side so the handle sticks out from under it far enough to stand on it or even stomp down on it. if you need to keep it from turning, put the ujoint keepers on and wedge something into the yoke that will catch the frame so it cant turn. if all else fails do like the coyote and purchase a pinion nut blaster from ACME. best of luck, ron
"Ochre Ogre"
You do know that you need to get the pinion nut back on the exact number of turns that you take it off? This is what sets the depth of the pinion in the ring gear. Too loose or too tight and they will be junk in a matter of miles.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Hi there,
Thanks for the replies, yeah I know about setting the pinion etc. Tried again for 4 hours, the sucker still wont come un-done....Grrrhhh Cheers
#5 | |
Try heat around the bolt to see is the housing won't expand just enough to turn loose of the bolt. righty tighty lefty loosy!! |
#6 | |
Having issues
Heat on the nut, ice on the pinion ![]()
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
#7 | |
I thought it was a bolt into the housing? If so then heat the housing and the bolt backs out? If you heat the bolt and ice the housing the bolt expands and the housing shrinks and it becomes even tighter, if I have this wrong (which I might as I have never personally worked on one of these) LMK, but I have seen picts and if memory serves me correctly the advice I gave is correct. |
I did one a while ago, no cheater bar in the world will work, the only thing that finally worked was a man sized industrial impact gun, after heating the nut with a torch.
To make this easier, you can unbolt and remove the pinion flange/pinion assembly and take it to a truck garage. I mean a big truck garage. Its a bear.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
While a go I took mine to a big rig shop and the guy there heated the nut and rapidly added water until it was cool to the touch then a torque wrench till the nut berly moved wrote the force down and then a 1/2" impact from there. New nut with some anti sieze to keep things easy for the gear change.
The best tool for the job imo is an 1/2 inch Electric impact gun , I sure wouldnt use heat on it
i did mine today,man was that sucker on there, i had my whole chunk out tried holding the yoke with a big pipe wrench and turning nut with a 3/4 "breaker bar. yea right.so i got the bob-cat set the bucket down on the pip wrench slipped a pipe over the breaker bar and lifted the bobcat. so i tried heating the nut with a little propane tourch and adding weight to the bobcat bucket, still no go oh i forgot to mention the 600 ft/lb inpact that did nothing. so i broke out the blue wrench and heated her up good then she finialy broke loose in i finished her off with the impact. factory service manual makes no mention of marking and reinstaling in same posistion for an eaton but i did mark it for referance, it says toquqe it to 200 ft/lbs.itsays nothing about setting or ajusting backlash but lists .005-.008 as perfered and min of .003 and max of.012". is backlash ajusted by shimming or what? and how do you check it? i havent assembeled it or checked it yet because i need to get a speedy sleave for my yoke
common sense isn't so common anymore |
chiltons truck manual has a very detailed eaton overhaul section, it seems the pinion yoke nut does not set pinion depth it states 325-400 ft/lbs fo 11/8 pinion shaft
#13 |
Hmm interesting info about the nut not setting pinion etc.
Still trying to get the nut off ![]() I even jacked the burb up set ul a breaker bar on the nut then slowly lowered the burb back down hoping the weight would add enough leverage on the bar and then undo the nut.....Err no chance...breaker bar just took the full weight and movement from the nut.... Also used my air gun still no use... Think its off to a truck garage!
#14 |
Aluminum slot wheels rule...
Did you try some PB Blaster or Deep Creep on the threads. I swear those two oils work good on frozen stuff.
#15 |
Project92 SWB stepside
You will have to heat it to loosen the locktite that is on the nut threads.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#16 |
I got all bound up eatin`pinon pine nuts once.That what I get for listening to Ewel Gibbons.
Listen to Phantom Dually,get that sicker hot.
#17 |
OK going to try some heat this week, anyone know where I can get a new Pinion nut from that ships to the UK? Appears Rock Auto dont do them
![]() Cheers
#18 |
I can`t tell.Is your Suburban a 10 or 20 series?Someone could set you up,I`d think.
#19 |
Hi , Its a C20 350 4 Speed but with 8stud HO52 rear and 8 stud front as well.
#20 |
Does Randy's Ring & Pinion ship overseas?
http://ringpinion.com/ Need someone to call them toll-free?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#21 |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Let me contact them. I work just down the street from them and buy a ton of parts from them. I will call them on Thursday afternoon when I get to work.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
#22 |
If you hit the side of the nut with an air chisle or just a hammer and chisle, it will in time loosen. Something else to try is put a breaker baron the nut, with the bar on somthing solid, and push or pull the truck, mabee even hitting the end of the bar and soccet with a BFH (big hammer) Be sure to take precautions not to get run over. I have yet to have a nut, or bolt beat me. If you have any more troubles bring it by and I'll get it off,,, NO CHARGE
#23 |
englishrodder, Just got back from Randy's Ring and Pinion. That nut is torqued to 175 ft lbs. After 30 + yrs you will need to soak it with some good penatrating(sp) oil for a couple of day then heat it up. Also contact a machine shop and see if they have any pentatrating wax that also works.
If all fails go down to the local pub and find someone alot larger than you to help.LOL. Good luck
#24 |
Thanks guys for the info, Tried the heat and the oil. I just cant get enough swing on the breaker bar as I cant get the burb high enough.
Its booked into a mates garage so he can put it up on the 4 poster, that we we can both swing of a large breaker bar.... More updates in a week or so... Cheers
#25 |
Well its finally fixed, 1.5hrs at a local garage!
![]() Now I can get on with sorting what drop coils/spindles i need etc. Thanks for all the help/info guys
