Radiator which tranny lcooling ine is which?
I'm correct in assuming the top tranny cooling connection on the radiator is the pressure out line of the transmission and lower tranny cooling line is return to the inlet side of the tranny? Almost there - fill tranny / eng with fluid, install tranny temp gauge, set timing and "cleaaarrr...contact"
thanks!
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI ![]() |
its all about the +6 inches
Re: Radiator which tranny lcooling ine is which?
it really doesn't matter.
The top one from the tranny is to the cooler, the lower one is from the cooler. |
Fabricate till you "puke"
The bottom on the trans cooler is pressure IN, & the top is return to the trans.....It feeds from the bottom to the top to help eliminate air pockets, and or foaming. CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thank you
