Old 04-30-2006, 02:29 PM   #1
Don Brace
Active Member
WTB 8 bolt leaf spring rear end 1971
Looking for a complete rear end. Do not need the springs. I bought a 1971 long bed missing the rear end.
Thanks for any help.
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 05-02-2006, 06:16 PM   #2
RicksTrucks
RicksTrucks's Avatar
Re: WTB 8 bolt leaf spring rear end 1971
Got this one, but shipping may be a killer.
http://67-72chevytrucks.com/vboard/s...d.php?t=197330
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 05-02-2006, 07:00 PM   #3
I have a 4.10 Dana60 rear,same deal-heavy/far.
Old 05-02-2006, 07:26 PM   #4
Don Brace
Active Member
Does anyone know if I can use a rear end from a trailing arm set up. Can I weld some thing on the housing to use for a spring purch and then use U bolts to hold it together?
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 05-02-2006, 08:40 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would advise you to call the parts stores and price normal stuff like brake shoes and drums and brake cylinders... you may want to find a later model rear once you see the stupid prices (and non-avalibility) of the parts.
Old 05-02-2006, 10:27 PM   #6
wibilly
wibilly's Avatar
i have a 14 bolt full float rear here with 4.10s and open diff from a 73 or newer. spring perches will need to be relocated near Sponner and Hayward WI
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-03-2006, 06:12 AM   #7
Yes,you can adapt the axle from coil to leaf.It takes alot of care to get the pinion angle right and both sides the same.
Old 05-03-2006, 07:28 AM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
I have a 14 bolt with 4.11's from a 96 G30 I would sell. I also have coil spring Dana 60's with a 3.54 posi or a 70 Eaton 4.56 rear with a Detroit Locker. I got you covered and I am only 2 hours away.
and ditto on relocating the spring perches, easy to do with a little skill.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-03-2006, 01:40 PM   #9
cadiac
Have a dana 60/8 lug from a 69/had leafs/very good, but down in Kansas. I go to Sioux Falls once in awhile but it'll be august or so.
cadiac is offline   Reply With Quote
Old 05-03-2006, 07:15 PM   #10
wibilly
wibilly's Avatar
da-burb what ya gotta have for the danna? i like the gearing just wish it was set up for leafs
