Old 07-29-2002, 05:03 PM   #1
72sleeper
[]D [] []v[] []D
Angry help please....still broken
this is pissin me off ive posted about it many times and i cant getit fixed and my dad is so lazy, but anyways my c10 when i first start it it runs fine but after about 10 minutes it starts to miss and my oil pressure gauge starts jumpin and i have to put it in nuetral when stopped so it wont die on me and i thank yall for the help but ivechecked the valves there fine(and if it was the valves wouldnt it be regularly missin instead of verysparatic?) and ive put in thicker oil (15w50) then that didnt work so i put in lucas oil thickner didnt work either, im thinkin it has to do with heat cause when my compartment is cool its fine but when i drive around for a lil it starts to do it after the heat builds up so any help would be great thanks..............
Clint
72 c'10 350ci/400hp
sleeper forever
72sleeper is offline   Reply With Quote
Old 07-29-2002, 05:16 PM   #2
colohusker
What is your intake combination? carb, intake, etc? The missing and poor running sounds to me like flooding. If your running an edelbrock, do you have a fuel pressure regulator? I know edelbrock's don't like more than 6 psi of fuel or they overflow their float and dump fuel down the primaries. Another thing might be the route of your fuel line. If it's too close to the exhaust, might be getting too hot and vaporizing on you. Just thoughts.. keep us posted as to what you find out...
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 07-29-2002, 06:07 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yeah, describe your set up...esp all the external parts in detail. Maybe we can nab this in the ass.
Old 07-29-2002, 11:48 PM   #4
72sleeper
[]D [] []v[] []D
its a brand new 4 bolt main, 350 bored over, with mild cam ,and a stock intake with holley 500cfm 2bbl, the heads arent stock but there not built like crazy im to sure on the valve sizes and stuff the motor was only 500 and worked fine so i didnt ask alotta questions and ive had it about 6months, i got the carter 650 sittin on my performer intake in my garage i just wanna fix thetruck first i have braided fuel line and its not really close to my headers so i dont think that could be it thanks
Clint
72 c'10 350ci/400hp
sleeper forever
Old 07-29-2002, 11:52 PM   #5
Super Chevy
Super Chevy's Avatar
I'm thinking mabe you fuel level isnt set? you ever set it recently?
Super Chevy is offline   Reply With Quote
Old 07-30-2002, 12:02 AM   #6
Denny
Denny's Avatar
You probably already checked this but does your choke open all the way up after the engine warms up? Also what is the deal with the oil pressure? Are your lifters making noise?
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 07-30-2002, 12:47 PM   #7
Blazer1970
Blazer1970's Avatar
Oil pressure will sometimes drop just because the idle is so low as the engine is about to stall. I would make sure the choke is opening all the way as Denny suggested.
Blazer1970 is offline   Reply With Quote
Old 07-30-2002, 03:55 PM   #8
ibjoker69
hahaha
I look for the simple solutions. A clogged filter or a clogged fuel line. I had a 68 shelby that at some point a extra filter was placed in the line and I had the same type of truble and it took me two months rebuilding the carb, and the distributor checking pressures and pushing it around town. I blew out the line with air ect. and findly found this filter with a gello like clog in it. So look for a clog these trucks have had alot done to them and at any time the gas in the tank could have congeled, or it just has junk in it. I would have sold the Shelby cheep if I could have gotten it to run over 30 min.. I was that upset. That was my gripe Joker69
69lwb, 29 A coupe hotrod, 55 chevy hardtop,
ibjoker69 is offline   Reply With Quote
Old 07-30-2002, 05:12 PM   #9
bigjimzlll
bigjimzlll's Avatar
do you have an oil sending unit type of oil pressure gauge?,,it could be shorting out, causeing the engine to try to stall
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-30-2002, 06:08 PM   #10
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
The bus did the same thing to me a couple weeks ago. I replaced the fuel filter (cleaned all the rust out the sediment bowl too), dumped a half-gallon of kerosene (cheaper than drygas by far) in the tank, changed the points, and pulled the carb (crow-sucking Holley 2bbl) apart. All that didn't do a thing. Still ran horribly. So I acted on a hunch and messed with the needle & seat. Once gas started pouring out the sight port, the bus no longer had that stalling issue.
Check your float bowl fuel level once you have the truck running (a 10 minute window is more than enough).
On a side note, how would an oil pressure sending unit shorting out cause an engine to stall? The sending unit is already grounded. If the wire going to the sending unit shorted out, the gauge would go berserk, but the engine would not stall.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 07-30-2002, 06:20 PM   #11
busterwivell
I had this problem with my 402 right after it was rebuilt. Had it towed a few times, rebuilt carb when engine built. Could get to idle fine, but running down the road would die and not restart. Long story short......the fuel filter inside the carb was TWISTED and would limit fuel supply to the point it would starve. Simple cheap fix that bugged me for a couple of months GGGRRRRRRR.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 07-30-2002, 11:39 PM   #12
bigjimzlll
bigjimzlll's Avatar
ok..im stupid..and im an electrician..lol..I stand corrected.. still trying to figure out all this auto electric stuff..using the ground for a switch leg..geez who'd a thunk
Anderson,CA
Old 07-31-2002, 02:08 AM   #13
72sleeper
[]D [] []v[] []D
my choke is manual so its always open thats not it if it was somthin clogged though wouldnt it happen all the time not just after it gets warm underthe hood???
Clint
72 c'10 350ci/400hp
sleeper forever
Old 07-31-2002, 05:14 AM   #14
OhioDan
OhioDan's Avatar
Had a 59 Pontiac that had a similar problem. Ran fine until it warmed up, then it would go to crap. Come to find out, the previous owner had overheated it so bad, that it drew the temper out of the cam. When it would warm up, the cam would whip around like a wet noodle. Swapped cam, and the problem went away. Just my $.02 .
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 07-31-2002, 09:42 AM   #15
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
What kind of ignition do you have? Point or HEI. Mine did the same thing when I had points. What kind of condition is your plug wires in? Are they rubbing the exhaust? Are they arcing when they get warm? What is the gap on your plugs? They should be .045. How about the cap and rotor?
What is the clearence on the rod and main bearings? If known.
Are the lifters in good shape with no restriction in movement?
How many miles is on the cam?
Just a few questions.
Ben
67Fleetsidedream is offline   Reply With Quote
