04-30-2006, 07:46 PM | #1 |
Am I screwed?
The 327 I was planning on using has bad heads (not rebuildable). Do I have to go and try and hunt them down or can I use another set of heads like off of a 350 or even 305?
I was told by gramps I could use any other head but sometimes I think the Milwaukees Best gets to him! I figured I'd go for some profesional advice befor I sink the money into this rebuild kit I planned on ordering!
http://www.adicustoms.com/ |
04-30-2006, 07:53 PM | #2 |
Junior Member
Re: Am I screwed?
You can use a set for 305, unless you want to loose some compression. Any stock type SBC head will physically bolt on.
The other option would be to use a set of higher c/r pistons with a pair of 350-400 heads.
Jeff J ---------- 86 El Camino 81 Monte Carlo 81 Regal 04 Colorado |
04-30-2006, 11:41 PM | #3 | |
A little east of nowhere
Re: Am I screwed?
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
05-01-2006, 08:29 AM | #4 |
Re: Am I screwed?
is this true even when going oversize on the bore?
or what about jetting the carb a little different! This sounds like its going to be a nightmare, I may just try and find a 350!
05-01-2006, 08:41 AM | #5 |
Re: Am I screwed?
call some local machine shops they usually have heads laying around ready to install. here in tulsa there is one called tuter (sp?) it is around downtown i think third street talk to terry he is an aquantince and ownes the place.
square body trucks an addiction or an investment either way they consume all my extra time and money |
05-01-2006, 09:40 AM | #6 | |
Re: Am I screwed?
05-01-2006, 09:49 AM | #7 |
Re: Am I screwed?
yeah agreed and lucito is freakin awsome but he dont have much of a surplus that shop of his is the first and only machine shop that i would eat of the floor im not familiar with 327's other than most people i hear talk about them run 194 heads not sure what the deminsions are as far as valve sizes i can make some phone calles and see what i can find through my conections around here ill keep you posted 86gmg
05-01-2006, 10:11 AM | #8 | |
Re: Am I screwed?
I know thats what Im doing on my lunch break today!
05-01-2006, 12:47 PM | #9 |
Re: Am I screwed?
Some Vortec heads should work well w/a 327 sbc. Have you considered them?
05-01-2006, 12:50 PM | #10 |
www.73-87chevytrucks.com
Re: Am I screwed?
Ditto on what Scoti says. I would go for a decent set of Vortec heads.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-01-2006, 01:59 PM | #11 |
Re: Am I screwed?
leks tuder machine has 327 heads ready to bolt on except for the springs and
rockers 300.00 with a core since yours are bad 400.00. i may be able to get a better deal if we were to go together maybe like stasted above an aquantence buddy deal if were lucky. so far thats the best i can come up with. personally buying a set from some one and then rebuilding them would be about the same if not more. i will pm you my cell number to hook up if you want
05-01-2006, 02:39 PM | #12 |
No No
Re: Am I screwed?
Theres nothing special about the 327 heads even if they were double hump heads the only advantage they would have over a set of 416 305 heads would be the valve size and the 305 heads have smaller combustion chambers and actually larger ports where it matters.
Get any set of SBC heads and they will work fine.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
05-01-2006, 06:18 PM | #13 | |
Junior Member
Re: Am I screwed?
327 = 64CC 305 & 267 = 58CC
05-02-2006, 08:46 AM | #14 | |
Re: Am I screwed?
05-02-2006, 12:07 PM | #15 | |
needin' money
Re: Am I screwed?
SWB Stands for Short Wide Bed |
