05-01-2006, 07:39 PM | #1 |
Captain Ed
Window crank stem too short
My window regulator stem (where the crank mounts to) is too short. With the door panel on, I cant get the handle to go in far enough to tighten the set screw. Even without a felt pad, it won't do it. I bought the regulator a couple of years go from GMC Paul. Anyone run into this problem? Solution?
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L |
05-01-2006, 09:05 PM | #2 |
Re: Window crank stem too short
you used to be able to buy extensions for customizing vans.jc whitney?
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
05-01-2006, 10:00 PM | #3 |
Cantankerous Geezer
I'd start by contacting GMC Paul. He's usually pretty good with customer service and advice.
Fred There is no such thing as too much cam...just not enough engine. |
