Old 05-02-2006, 07:08 AM   #1
locab36
locab36's Avatar
69 loss of lights, Q's and help...
Last night on my way to work I lost my brake lights, park lights, instrument lights, dome light . Still have turn signals and flashers and headlights only. I checked all the fuses and they are fine . I have a feeling that the culprit is the light switch. Checking the online wiring diagrams the brake light switch runs through the dome light circuit which then runs through the light switch? Has this happened to anyone before?
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 05-02-2006, 11:23 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 69 loss of lights, Q's and help...
Most likely is the headlight switch. It is fairly simple to swap and should be available at your local autoparts store.
On Blazers, the dome light does not run through the brake switch. I had a problem with a trailer brake set up on my '72. It was a very clean instal (I suspect it might have been dealer installation because it was so clean) but the brake lights ran through the trailer brake set up. The switch in the set up went out and killed my brake lights. Luckly, Mr. Police officer was very nice and just told me about the problem and said I should use hand signals to get home. I routed the brake lights the original way and all worked fine again.
On my '69, I had the brown wire from the headlight switch burn. There was a small knick in the wire and it shorted out when the lights were on. It filled the cab with smoke and melted the plastic coating off the wire. It was a pain, but an easy fix.
Check your wires to see if they are in good shape.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
