Old 05-02-2006, 01:35 PM   #1
cstanley
cstanley's Avatar
Fuel Filler Location
in reference to this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=197123
how hard do you think it would be to run the fuel filler neck from the stock location to a fuel cell in back? anyone done it? if it's reasonably possible, i wish i'd thought of it
it just sounds cool to fill the fuel in the stock location, but not have the tank in the cab. can it be done? huh? huh? can it??
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 05-02-2006, 01:41 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Fuel Filler Location
Are you talking about the fuel filler on a 55 body or 67-72 body? If it's the latter you would have WAY too much hose running, it would probably be VERY slow to fill. I would recommend doing the side marker fill on a 68-72 for the rear tank, it's an easy mod and most people never notice.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-02-2006, 02:08 PM   #3
cstanley
cstanley's Avatar
yeah, i was talking about doing it on a 67-72. i was just wondering, b/c i like the thought of a completely stock look (including the factory filler) but with modern advances/functionality (plus, i don't have a welder or any welding buddies to patch the filler hole. )
it would be a long way for the fuel to go, but i don't mind waiting at the pump. i'm just curious as to whether it could be a decent solution, and would it work? i suppose there would need to be the filler neck tube, along with the overflow tube running alongside of it? what kind of hose would i use?
'course if i wanted to maintain stock appearance, i could always just leave the filler neck and gas cap in place, as well as doing the side marker filler.
thanks
Old 05-02-2006, 02:14 PM   #4
motocrosschump
I am pondering a simiar setup going from stock filler location routing through cab into bed into a fuel cell.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 05-02-2006, 03:17 PM   #5
71swb4x4
71swb4x4's Avatar
I did the side marker fill on my SWB, and I didn't want to weld up the other hole so I took a long bolt and put it on the inside, and wire tied the cap to it. I left the gasket on, so it looks stock, but you can't get the cap off.
Old 05-02-2006, 03:33 PM   #6
motocrosschump
This what I was talking about.
The only concern I had was the filler hose between the cab and bed .
Old 05-02-2006, 04:11 PM   #7
matthufham
my previous owner proved you don't need a welder to patch the old filler hole. looks like scrap metal rivited in, and bondo'd over
matthufham is offline   Reply With Quote
Old 05-02-2006, 04:24 PM   #8
cstanley
cstanley's Avatar
WOW
Old 05-02-2006, 04:38 PM   #9
wrapumup
Junior Member
I thought the side marker filler, pics and thread was on a stepside, is yours a stepside 71swb?
wrapumup is offline   Reply With Quote
Old 05-02-2006, 05:24 PM   #10
1LoC10
Insert Title Here
1LoC10's Avatar
just move t in the bed and do a different type of filler... but just leave the stock cap there just for looks. it dont need to be real
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-02-2006, 05:39 PM   #11
71swb4x4
71swb4x4's Avatar
Nope, fleetside. It's pretty easy to do on a fleetside, you just have to extend your stake pocket to hide the tube. Some have actually gotten it all to fit in the bed side, but it's tight.
Old 05-02-2006, 07:48 PM   #12
matthufham
i would of said that for the fleetside, but he doesn't have a welder
Old 05-02-2006, 10:55 PM   #13
cstanley
cstanley's Avatar
yeah, i just need to go get a welder. it'll save me in the long run. i just have to work back up to it. i had a decision to make with my collection of lowe's gift certs: a welder or a tablesaw. too many house projects looming on the horizon persuaded me to the tablesaw. i should have known better.
