Old 05-02-2006, 02:21 PM   #1
WakBordr7387
WakBordr7387's Avatar
Small block to a big block
On my 86'SWB, It originally had a 305 in it, which was replaced with a 350 and now Im about to replace that with a big ass 454. I know the transmission will mount up just fine, along with the motor mounts and getting a new radiator to cool all those inches.
Will the stock pulley's for a small block fit the 454? and is there anything else I need to swap out for the 454 to fit right?
86' C-10 Silverado
85' C4 Corvette
When in doubt, BURN OUT!!
WakBordr7387 is offline   Reply With Quote
Old 05-02-2006, 02:39 PM   #2
SSC's76
No No
SSC's76's Avatar
Re: Small block to a big block
The pullys and brackers are different so your going to need them also. Some people have modified some SBC brackets to fit a BBC but it would probably be easyer to buy them then attepemt to make brackets and spacer to mount the pullys.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-02-2006, 03:08 PM   #3
86 GMG
it would easier and a lot safer in my opinion to get the bbc stuff like SSC said
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 05-02-2006, 03:47 PM   #4
rockman20
"The dude abides"
rockman20's Avatar
Dumb question maybe since I don't know about your project. What have you done with the front suspension? Is it ready for that extra weight?
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 05-02-2006, 04:34 PM   #5
WakBordr7387
Thanks guys, Ill see if I can't find a truck that had a big block in it and steal the pulleys and all that off of it.
I completly forgot about the extra weight, and I haven't touched the suspension. Do you think I need new springs or anything else?
86' C-10 Silverado
85' C4 Corvette
Old 05-02-2006, 07:08 PM   #6
SanitysBane
Only if you feel like it. When I put in a big block in my truck I used the factory small block springs. It sat down maybe 1/2inch lower.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 05-02-2006, 07:29 PM   #7
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Get a bigger fuel tank.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 05-02-2006, 11:04 PM   #8
C&C Chevy
C&C Chevy's Avatar
Funny, I was just about ask a "How to go from a smallblock to a v-6" thread!
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 05-03-2006, 12:36 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
When you find the BB truck get a few more parts besides the pullies and brackets. You will need the radiator cover, fan shroud, and radiator mounting rubbers to make that four row wide core radiator fit.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-03-2006, 10:49 PM   #10
f.monroe
f.monroe's Avatar
You probably know this but I would check the flexplate against the torque converter before you drop the BigBlock in . I think there are two different bolt patterns on some flexplates and or some torq converters . The 454 uses an externally balanced flexplate , and the 305/350's are internally balanced ,so I am sure you will be using a different flexplate than the one currently installed and it might be worth your time to check the pattern first . Just a thought . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
