Old 05-02-2006, 08:32 PM   #1
partsman9606
a country boy can survive
partsman9606's Avatar
headlight sockets
is there anyone else who is having problems with these trucks headlight sockets burning up??? my 91 did it and now my 99 tahoe is burnt, i have the same type of headlight in both of them but they are just the silverstars.:nut:
1991 c/1500 lowered 2/4, 6inch cowl hood
1988 c/1500 plain(girlfriends truck)
1999 chevy tahoe z71
partsman9606 is offline   Reply With Quote
Old 05-03-2006, 05:39 AM   #2
Re: headlight sockets
Never noticed the problem in my 92 or 96, but I just had the factory bulbs in there.
Old 05-03-2006, 08:44 AM   #3
rockman20
"The dude abides"
rockman20's Avatar
I have never had the problem either. But, I to have just the stock bulbs.
You really need to be careful when you go with a brighter bulb. You need to make sure that the draw is not higher then stock. There are some people that I know that went out and bought a brighter bulb and started burning things up. When you checked the draw on the bulb, it was higher then stock. Would explain why things burn up!
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 05-03-2006, 07:04 PM   #4
partsman9606
found the problem on both just a bad connection, thanks
Old 05-03-2006, 08:38 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
If you want to run more light than what the factory sold, I would recommend a seperate wiring harness to get the heavier wire and plugs for the wattage. The harnesses go directly to the battery and does not overload your light switch and possibly burn up the wiring and circuitry in it. The direct connection ensures that you get the full voltage from the battery and not the reduced voltage that is the result of going through the light switch and wiring.
piecesparts is offline   Reply With Quote
